Rear Gear Noise - JeepForum.com
post #1 of 6 Old 11-16-2013, 02:24 PM Thread Starter
Cuzzzz
Cuzzzz's Avatar
Rear Gear Noise
I have a 1994 wrangler with 33x12.50's and on my way out to work the other morning I was shifting gears and POW!! The rear end sounded like a gun went off and a bad vibration started. I was lucky enough to get it back home and I just pulled the rear cover and found what looks to be a 3/8 bolt head from the ring gear laying in the bottom of the housing. My question is would this be a easy fix or should I try to find a junked out jeep or purchase a new one?? Thanks.
Cuzzzz is offline
post #2 of 6 Old 11-16-2013, 07:18 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
If nothing else is damaged, and you can replace the ring gear bolt, then you should be fine.
I would be sure to re-torque the rest of the bolts while your in there.
jeepdaddy2000 is offline
post #3 of 6 Old 11-17-2013, 09:47 AM
Evildriver-3
You're gonna change the rear for a UNKNOWN out of a JY and you have the issue right there ????
Get new BOLTS, remove all of them and re-install them with red locktite, you can do it with the carrier in place.
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #4 of 6 Old 11-17-2013, 10:23 AM Thread Starter
Cuzzzz
Cuzzzz's Avatar
The gear oil looks like grey metallic paint and this thing has over 200,000 miles with over 100,000 of those wee on 33 x 12.50's I don't want to have to worry about this again. So I can pay it now or pay it later.
Cuzzzz is offline
post #5 of 6 Old 11-18-2013, 02:28 AM
copmedic309
1995 XJ Cherokee
As long as the gears are in good shape, you should be fine. With the bolt out, slide out the main pin, remove the C locker, and take out one axle at a time. Just check it, make sure there's no damage. Cheaper to replace the axle for the JY or a new one, compared to a junker jeep you know nothing about or droppin cash for a new one.
Ry.
Rather be tried by 12, than carried by 6.
copmedic309 is offline
post #6 of 6 Old 11-18-2013, 02:28 AM
uberxj92
1992 XJ Cherokee
Evil is right. Just do the bolts. No sense in junking a good rig.
https://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
