Really need help ax5 to ax15 - JeepForum.com
post #1 of 8 Old 09-18-2021, 12:37 PM Thread Starter
Tuckeryj
I have a 92 yj that had an ax5 that went out on me so I figured this was a good time to swap it for an ax15 using the advanced adapter kit. I've had it driving and installed a few times now but keeping having to drop it because there's this ticking sound that I can really hear in 3,4, and 5th gear. It can be heard when pushing on the gas or heard louder when the clutch is pressed in but after the transmission seems to slow down from speed it disappears.. This is only when moving that I can hear it. I've replaced the pilot bearing, throwout bearing, clutch, pressure plate and I got a rebuilt retransmission after the noise persisted awhile. There is a burning smell that I believe might be the clutch but I read it might do that while breaking in but it's been around 400 miles still with this smell.
Tuckeryj is offline
post #2 of 8 Old 09-18-2021, 01:03 PM Thread Starter
Tuckeryj
Is it possible my clutch isn't fully disengaging?
Tuckeryj is offline
post #3 of 8 Old 09-18-2021, 05:42 PM
rjbruzan
A new clutch does not smell when being broken in. Something is wrong. Perhaps the throw out bearing is not completely releasing or is bottoming on the trans.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #4 of 8 Old 09-18-2021, 09:54 PM Thread Starter
Tuckeryj
And how could I approach it if the throwout bearing isn't disengaging
Tuckeryj is offline
post #5 of 8 Old 09-19-2021, 07:21 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Your terminology is confusing. Do you mean you have had the trans and clutch assembly totally removed and reinstalled a few times already and still can not find the problem?
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" Patagonia M/Ts, AX15, NP231+4:1+SYE+2LO, York OBA.
Web Admin for
JeeperDon is offline
post #6 of 8 Old 09-19-2021, 11:41 AM Thread Starter
Tuckeryj
Yeah. I've taken both assemblies out multiple times but I do believe the problem to be the clutch not fully disengaging but I don't know how to fix this issue
Tuckeryj is offline
post #7 of 8 Old 09-19-2021, 12:40 PM
Thorwon
Is the clutch disc in backward? If it is the jeep will make all kinda strange noises.
DON"T ASK ME HOW I KNOW THIS!!!!
Be Worthy
Thorwon is offline
post #8 of 8 Old 09-19-2021, 09:33 PM Thread Starter
Tuckeryj
I've made sure everytimeg to put the flywheel side towards the flywheel but that's good to know
Tuckeryj is offline
