I currently have a SOA setup on my 77 CJ5 and would like to switch back to a spring under setup and install an OME 2.5" lift. Unfortunately I don't know how to weld so I'll need to get it to a shop but getting it there is my issue. Is it safe to just bolt the spring perches in place, get everything set the way you want it and drive a few miles to get the perches welded? Hoping to avoid paying labor for someone else to get the pinion angle adjusted and the axle centered above the springs.
Hopefully this isn't a stupid question.
