PCV tied into brake booster vacuum? - JeepForum.com
post #1 of 4 Old 11-06-2008, 07:45 AM Thread Starter
Calebster
1979 FSJ Cherokee
I am installing a 2100 on my 258. The carb I got cheap is an older one with no PCV on the back. Can I just tie into my brake booster line which is under my blocked off EGR spot. Also, any help on recommended locations for where the dist vacuum line needs to be connected.
Thanks a million for any help!
Calebster is offline
post #2 of 4 Old 11-15-2008, 09:16 PM
carnuck
1984 J-Series Truck
Only if you want to lose 1/2 your braking power!
carnuck is offline
post #3 of 4 Old 11-24-2008, 08:27 AM Thread Starter
Calebster
1979 FSJ Cherokee
Where could I tie it into and not lose my braking power?
post #4 of 4 Old 11-24-2008, 07:28 PM
ctm
About 1/4 of the way down the left hand menu on this page there is a ton of info on 2100 vacuum setups
http://www.geocities.com/cantwait_fo...e_library.html
ctm is offline
Front shackle mounts tied into frame (pics) webdr Fabrication Shop 7 07-02-2010 06:58 AM
Factory stereos tied to VIN? PhillyUnion2010 Audio, CB & Ham Radios, GPS, & Electrical 12 09-01-2009 11:04 AM
Brake booster vacuum leak? Neckball Engines & Drivetrain 2 11-30-2007 03:05 PM
tire carrier tied to tail gate with hinge on bumper ej's tj Fabrication Shop 0 04-03-2005 07:18 PM
brake booster walterphilippo General Jeep & Off-Road Equipment 1 01-05-2005 12:30 PM
