P0871 Code need help - JeepForum.com
post #1 of 3 Old 06-30-2020, 09:56 AM Thread Starter
RockRoller
2009 JK Wrangler
Hello all,
I'm new to the forum and need assistance with this code issue. I have a 2009 JKU that is throwing this code, but it only throws the code when I stop suddenly or take a sudden right turn from speeds higher than 30mph. Or at least that's what I have observed. If I clear the code and drive around town (~30MPH) then the code doesn't pop up. If I'm coming off the highway and stop at the light, the code pops up. I can almost predict it when driving home from work everyday. I have no other codes and the jeep is otherwise running fine. No limp mode or hard shifting. The jeep does have an auto trans. Any help would be appreciated.
RockRoller is offline
post #2 of 3 Old 06-30-2020, 10:10 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
P0871-OD PRESSURE SWITCH RATIONALITY
Theory of Operation
The Transmission system uses three pressure switches to monitor the fluid pressure in the L/R, 2/4, and OD elements. The pressure switches are continuously monitored for the correct states in each gear. Normal operation will be experienced if no other codes are present. Transmission Control System will ignore the code. Limp-in condition will only occur if DTC P0871 is present with a DTC P0706.
When Monitored: Whenever the engine is running.
Set Condition: The DTC is set if one of the pressure switches is open or closed at the wrong time in a given gear. If the problem is identified for 3 successive key starts, the transmission will go into limp-in mode and the MIL will turn on after 10 seconds of vehicle operation.
Possible Causes
RELATED TIPM DTCS PRESENT
LOSS OF PRIME DTC PRESENT
OD PRESSURE SIGNAL CIRCUIT OPEN
OD PRESSURE SIGNAL CIRCUIT SHORT TO GROUND
OD PRESSURE SIGNAL CIRCUIT SHORT TO VOLTAGE
TRANSMISSION SOLENOID/PRESSURE SWITCH ASSEMBLY
POWERTRAIN CONTROL MODULE
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 3 Old 06-30-2020, 11:48 AM Thread Starter
RockRoller
2009 JK Wrangler
Thx, I guess I’m looking to see if anyone has gone through this and they determined the likely cause. From other posts on this topic they experienced limp mode and/or the hard shifting where I am not. Probably just a sensor? Or should I go through a predetermined ritual.
