JeepForum.com (https://www.jeepforum.com/forum/)
-   Engines & Drivetrain (https://www.jeepforum.com/forum/f19/)
-   -   Oil recommendation for 4.0 (https://www.jeepforum.com/forum/f19/oil-recommendation-4-0-a-4360291/)
Markeje74 06-19-2019 07:40 AM
My 4.0 was nice and quiet on start up and run. I tried Amsoil Race this year because I use it in my bike and it's great. PLus a nap gold filter because I had it laying around. But now in the 4.0 I get the lifter clack on start up. What oil should I run to quiet this down? I do not remember what I had in before unfortunately. Pretty sure it was Pennzoil. I know I used a K&N oil filter.
mukluk 06-19-2019 11:28 PM
Use your choice of name brand 10w30 or 5w30 oil that meets MS-6395 or API SN.
biffgnar 06-21-2019 05:49 PM
If you change it regularly use whatever is on sale at the parts store when you walk in.
StrippedTorx 06-21-2019 08:57 PM
You sure you’re putting enough oil in it?
wildbill23c 06-21-2019 09:12 PM
My 98 says 5w-30, so that's what I use in it. Mine has the normal lifter clattering as well, not nearly as bad as the 2.9L V6 that's in my 1988 Ford Bronco 2 had before the engine was replaced though. Maybe add some zinc additive when you change the oil, that may help.
gutthans 06-21-2019 10:49 PM
May not be a 'brand' issue...More likely the weight of the Amsoil Race? What weight did you put in? What's your average temp there over the next 3 months?
75SV1 06-27-2019 01:25 PM
I was thinking the same thing. I am not sure how heavy of an oil a 4.0L can take. I did have a Ford Contour with the 4 cylinder or was it my SVT. I used a 20W-50 in it, Mobil 1. It clattered a bunch. I didn't run that oil long. Ran OK after that. (not a bash on Mobil 1).
I like to use Shell Rotella. The do make 10W-30 and 10W40. I like to use a bit higher zinc levels. I do use a NAPA oil filter. I am running Rotella T6 presently. Its a synthetic. Still, nothing wrong with conventional oils.
Also, you might lose a few MPGs with a heavier oil.
gutthans 06-27-2019 02:12 PM
"Hi-Mileage" oil tends to have the best zinc levels. I, however, am sold on Brad Penn Oils I get by the case from Summit. I run the 30w (Florida) Break-in Oil all year. LOTS & LOTS of ZINC. I researched that a looong time ago and did Valvoline Hi-mileage until I found Penn.
mukluk 06-27-2019 03:00 PM
Be careful about using oil with "lots and lots of zinc" as this can easily lead to catalytic converter damage. Yes, flat tappet engines like the 4.0L need more ZDDP than more modern designs to prevent excessive valvetrain wear, but you can quickly reach a point of having too much of a good thing which can cause problems elsewhere.
Unless your bearings and oil pump are worn to where you can't keep pressure in spec, there's not much point in running oil heavier than 10w30 in these engines.
gutthans 06-27-2019 04:37 PM
Good thought. I haven't run cats in years, so I don't worry about that.
75SV1 07-02-2019 06:19 AM
I think Rotella has 1,000 to 1,200 ppm of Zinc. The XJs or older Jeeps use older catalytic technology. So, that amount of Zinc shouldn't plug them as quick. I think the 'newer' speced oils use molybdenum or such. And again, I'd agree that to heavy of an oil can cause problems and MPG decrease. I've run 15W-40 Rotella before. I did not have any issues. Others run it too. I ran Rotella 10W-30 in the past few years. If you engine does not leak, Rotella T6 5W-40 synthetic is a good choice. Shows good to better wear rates than a lot of other oils, according to Blackstone Labs.
1998XJLtd 07-08-2019 08:10 PM
Ran Valvoline 5w-30 and a Mopar -090 filter for first 150k. Last 25k or so has been Mobil1 5w-30 syn and same -090 filter you can find for $5 at Wal-Mart. Pushing 180,000 on the odometer and no issues.
The time now is 12:11 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
