oil preasure guage - JeepForum.com
 1Likes
  • 1 Post By 80cj
post #1 of 5 Old 10-10-2019, 11:02 AM Thread Starter
cpjeep120
oil preasure guage
i have a 97 jeep cherokee country with a 4.0 inline 6 with alil over 235,000 original miles on the motor and i have been noticing the oil pressure would drop to 0 and when it goes up after driving it for a bit it will either be at 10 or 20 psi. i have replaced the valve cover gasket once and ive replaced the oil pressure sensor twice im on sensor three which is like a month old and its still doing it. when the gauge is at 0 nothing is happening to the motor it still drives fine. i dont know if this would effect it but the exhaust manifold is cracked at the collector which i plan on replacing soon once i order one. im gonna get a pressure gauge test kit and look up the pressure spec to see if the sensor is bad again or something.
if anyone has any other ideas that i can try that would be much appreciated
Jeep Learner Always
cpjeep120 is offline
post #2 of 5 Old 10-10-2019, 01:07 PM
80cj
80cj's Avatar
1980 CJ5
I'd put a known good mechanical gauge on it and see what the readings are. What grade oil are you running? With that many miles on the car, I would go up to a heavier grade.
jtec likes this.
80cj is offline
post #3 of 5 Old 10-18-2019, 01:56 PM Thread Starter
cpjeep120
i mostly run 5w-30 or 10w-30 but i normally always use 5w-30 when i do an oil change.... what grade oil would u recommend if i was to use a high grade cause at the moment its my daily driver and when i get a different car imma do a rebuild on it is my trans or torque convert dont go out before i get the chance to do that
Jeep Learner Always
post #4 of 5 Old 10-18-2019, 02:41 PM
jtec
jtec's Avatar
2014 JK Wrangler
X2 put a known good mechanical gauge on it and see what the readings are.
jtec is offline
post #5 of 5 Old 10-25-2019, 09:22 AM
Siva283
Siva283's Avatar
I am betting your bearings are getting worn. I would test with a mechanical gauge with your normal oil. But you should probably switch to 20w50. Its thicker to help take up the most likely now out of tolerance bearings. It might buy you time until you can rebuild.
Ask me how I know...
Siva283 is offline
oil gauge , oil pressure
