NP231 Rebuild Problems - JeepForum.com
post #1 of 5 Old 06-06-2021, 08:34 AM Thread Starter
TDENXJ
1996 Jeep Cherokee XJ Sport
4.0L, auto, NP231
First forum and first post - I hope I’m doing it correctly.
In the process of rebuilding transfer case but have couple problems.
1) my range shift fork and hub were toast and need replacement. Problem - the old part has casting number 16976. When I search for a new part (every online source possible or so it seems) I only find a new part with casting number 17833. I can only find used parts with original casting number. So, I bought one of each, a used 16976 and new 17833. They are similar but have enough differences to question the new part is a replacement for the old part. I’ve done lots of searching on internet and the ambiguity is maddening. IS 17833 A TRUE REPLACEMENT FOR 16976 on my 96 XJ with NP231?
2) I think that I trashed the used replacement 16976 that I ordered by trying to replace the plastic pads. I ripped out the old “molded in” pads before thinking things through and none of the new pads fit. The “molded in” pads are nothing like the design of the new pads. The casting uses holes with pegs rather then clip on with slots for positioning. Thoughts?
3) I ordered a used replacement range fork hub in great condition trying to save money. It is different than the original and question if new (used) is valid replacement for the original. Original hub has continuous internal splines. The used replacement has two gaps in the internal splines (three spline segments). At first glance it seems like it will work fine but I don’t fully understand how everything works together in order to have high confidence in my decision to use it. Should I be concerned?
4) after new bearings and seals, when reinstalling planetary gear set I noticed something questionable. After pressing the planetary gear into the input bearing it rotated with minor resistance. However, once I installed and tightened bolts on the bearing retainer the gear set rotated with much more resistance. It is smooth but takes more effort to rotate. Is this normal?
Any help is appreciated.
Regards
TDENXJ is offline
post #2 of 5 Old 06-07-2021, 02:33 PM Thread Starter
TDENXJ
Follow up to problem 4) I am comparing the original assembly with old seal to reassembly with new seal. Will a new seal add noticeable resistance on input gear shaft?
TDENXJ is offline
post #3 of 5 Old 06-10-2021, 07:46 AM Thread Starter
TDENXJ
Did I post this incorrectly?
TDENXJ is offline
post #4 of 5 Old 06-10-2021, 01:19 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
No, you posted fine. Since there are 418 views of this post so far, I suspect no one has run into your problem with enough recollection to give good advice. The last time I rebuilt my NP231 was in 2005. I opened it again in 2012 to add a new chain. I honestly don't remember things to the detail you need. This is generally helpful sub-forum, so hopefully someone can help.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" Patagonia M/Ts, AX15, NP231+4:1+SYE+2LO, York OBA.
Web Admin for
JeeperDon is offline
post #5 of 5 Old 06-11-2021, 09:03 AM Thread Starter
TDENXJ
Thank you for your input JeeperDon.
TDENXJ is offline
