Noise while idle and coasting - JeepForum.com
post #1 of 5 Old 05-20-2019, 05:01 PM Thread Starter
Rxvxs
Rxvxs's Avatar
When idle or coasting, the jeep makes a loud whistling noise. Idler pulley and belt replaced. Alternator is new. No check engine light is on. Have a video but site only allows images.
Rxvxs is offline
post #2 of 5 Old 05-20-2019, 05:05 PM
mukluk
mukluk's Avatar
Check for vacuum leaks around the intake manifold and throttle body.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 5 Old 05-21-2019, 07:13 AM Thread Starter
Rxvxs
Rxvxs's Avatar
YouTube Video of noise
Here is a link to a video with the noise:
Rxvxs is offline
post #4 of 5 Old 05-21-2019, 01:46 PM
mukluk
mukluk's Avatar
mukluk is offline
post #5 of 5 Old 05-29-2019, 11:33 AM Thread Starter
Rxvxs
Rxvxs's Avatar
Turned out to be the gasket for the intake manifold. So going to use that opportunity to replace the head and value cover gasket while I am there since value cover is also leaking a little. Thanks for your help.
Rxvxs is offline
Tj 2.5 high idle Broked TJ Wrangler Technical Forum 4 01-26-2019 05:54 PM
Irregular idle while coasting in neutral Rbeguelin TJ Wrangler Technical Forum 9 01-07-2019 07:35 AM
Idle control device when moving vs complete stop? JimE2 YJ Wrangler Technical Forum 30 01-01-2019 11:42 AM
The Mysterious Ticking Noise terminalninja WJ Grand Cherokee Forum 23 11-09-2018 10:26 PM
