No Start - JeepForum.com
post #1 of 3 Old 08-25-2019, 06:01 AM Thread Starter
JeepofWB
No Start
I have a 2005 Wrangler 4.0 that cranks but will not start. Pulled it in the garage last week and it was running fine. Went to use it a week later and it cranks strong but does not start. I have changed the crank sensor but that did not help. I'm thinking it may be the PCM. Is there a simple way to check it and if it is the PCM does anybody have an idea where to get a replacement?
JeepofWB is offline
post #2 of 3 Old 08-25-2019, 08:45 AM
jtec
jtec's Avatar
2014 JK Wrangler
So a no start = PCM ?
What diagnostics have we done ?
Attached scanner and observe data?
checked for codes?
Fuel pressure?
12v at coil?
12v at injectors?
Inj pulse?
Try this as someone tries to start jeep spray carb cleaner into throttle body - did it fire and try to start?
jtec is online now
post #3 of 3 Old 08-25-2019, 10:24 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What is missing during the no-start, fuel pressure, fuel injector pulses, or spark ?
Failure of the PCM should only be considered after complete and in-depth trouble shooting and diagnostics of the more common and more logical causes for the symptoms described.
Did you install a genuine Jeep Crank Position Sensor, or a cheap crappy Chinese clone auto parts store CPS ?
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
