No compression - JeepForum.com
post #1 of 7 Old 09-14-2020, 10:30 PM Thread Starter
Robert Worrall
No compression
2007 Jeep Compass 2.4. Timing chain jumped a couple cogs. I put chain back on to the timing marks and re tightened and wanted to check compression before I ordered a new chain and tightener. There is no compression on any cylinder. Is it possible that it bent a valve on every piston
Robert Worrall is offline
post #2 of 7 Old 09-14-2020, 11:32 PM
Tarneg
i had to look this engine up but it seems the pistons wont hit the valves but the valves will hit each other if the cams are turned independently of each other. this is only internet knowledge so grain of salt and all but if you have nothing then either they all hit each other or something else broke also and the next move is take the head off and see what up. (someone may have a cheat way to look from the top of the head without removing but i dont know it on this motor)
Tarneg is offline
post #3 of 7 Old 09-15-2020, 09:37 AM Thread Starter
Robert Worrall
It has 2 camshaft so i don't think the valves would hit
post #4 of 7 Old 09-15-2020, 10:12 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
If the cams aren't properly timed, the valves can hit each other if they open at the same time.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #5 of 7 Old 09-15-2020, 10:15 AM
Fourtrail
1974 CJ6
The valves are angled so if the cam shafts are out of phase with each other, then yes the valves can come in contact with each other.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #6 of 7 Old 09-15-2020, 11:22 AM Thread Starter
Robert Worrall
Ok. I guess head is coming off.. thanks everyone
post #7 of 7 Old 09-19-2020, 10:40 PM Thread Starter
Robert Worrall
head is off and all intake valves are bent, exhaust valves look good, pistons dont look damaged, there are marks on all pistons for valves, must be like that from factory. now to source parts
should i install new head bolts,
