Need some help - JeepForum.com
post #1 of 8 Old 07-20-2019, 09:52 PM Thread Starter
Mmorris88
Need some help
So I just got a 2000 Jeep Grand Cherokee limited given to me by family, I was wondering if any one could help me. It runs funny but when it's at a idle it idles just fine but soon as you give it gas or put it into gear it spits and sputters. Any idea of what it could be?
Mmorris88 is offline
post #2 of 8 Old 07-21-2019, 09:35 AM
jtec
jtec's Avatar
2014 JK Wrangler
codes. google getting jeep engine codes
fuel pressure. use a gauge
jtec is offline
post #3 of 8 Old 07-21-2019, 09:46 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Start with something simple...how does your air filter look?
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 8 Old 07-21-2019, 10:08 AM Thread Starter
Mmorris88
Air filter looks good. My uncle has had it in a few shops and no one seems to know what is wrong with it, he has changed two or three sensors, spark plugs, coil packs had the compression checked in the engine.
post #5 of 8 Old 07-21-2019, 11:46 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
OK, well you should tell us specifically what's already been done, or we're wasting our time guessing. "Changed 2 or 3 sensors" doesn't help. Which sensors?
What engine does you Jeep have? Are there malfunction codes stored in the computer and what are those codes? If it's been in several shops, someone has plugged into it by now to retrieve those codes. A good shop/tech would have documented that info.
Right now, we might as well be throwing darts at a chart. We don't have enough info on what you have and what's been done so far.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #6 of 8 Old 07-21-2019, 06:24 PM Thread Starter
Mmorris88
I get what your saying and I completely understand. I'm a novice when it comes to fixing cars I can do the basics. I will get more information on what has been done to it and I will get back. Also it has the 4.7 in it
post #7 of 8 Old 07-21-2019, 06:29 PM Thread Starter
Mmorris88
He change the throttle positioning sensor the camshaft sensor the map sensor replaced all the plugs and all coil packs I'm not a hundred percent sure of what the codes are throwing up because he had it in the shop two three years ago and he does not remember what the codes were
post #8 of 8 Old 07-30-2019, 02:43 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
TPS was changed? Did they adjust it properly?
Watch part 1 and part 2
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
