Need Help Identifing Axle Stub Shaft - JeepForum.com
post #1 of 7 Old 05-16-2019, 12:36 AM Thread Starter
BandAid6
BandAid6's Avatar
So I am in the process of replacing my front axle U-joints. Unfortunatly in the process I broke a part of the splined collar that goes around the short yoke
insert imaginary pic that I can't upload cause my post count is too low...
The replacements that I am looking at do not have this.
insert another imaginary pic...
I hope you guys can figure out what I'm saying with the less than stellar description.
What is this splined collar for? Can I just replace it without one?
Thanks for helping a newb with his first TJ, picked it up last week and getting it up and ready for summer!
Thanks
BandAid6 is offline
post #2 of 7 Old 05-16-2019, 12:46 AM
mukluk
mukluk's Avatar
The splined collar is an ABS tone ring for that wheel sensor. If your Jeep has ABS and you wish to keep it in working order, you'll need another tone ring.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 7 Old 05-16-2019, 12:50 AM Thread Starter
BandAid6
BandAid6's Avatar
And.... minutes later I’m that much smarter. Thank Mukluk!
BandAid6 is offline
post #4 of 7 Old 05-16-2019, 12:58 AM
mukluk
mukluk's Avatar
If you do find yourself in need of a replacement and wish to buy new, they are part number 4728984.
https://www.wermopar.com/oem-parts/m...-shaft-4728984
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #5 of 7 Old 05-16-2019, 01:30 AM Thread Starter
BandAid6
BandAid6's Avatar
Can a tone ring be added to one that does not have one?
2 New CV Axle ABS Tone Rings with Lifetime Warranty Replace Dorman 917-540 https://rover.ebay.com/rover/0/0/0?m...2F131165541960
BandAid6 is offline
post #6 of 7 Old 05-16-2019, 01:00 PM
mukluk
mukluk's Avatar
There's a good chance it can, provided the parts in question are the same dimensions as stock.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #7 of 7 Old 05-17-2019, 01:22 PM Thread Starter
BandAid6
BandAid6's Avatar
Thanks for the help... ended up pulling a stub shaft from the junk yard that had one. Knocked it off and swapped them out. Works great!
BandAid6 is offline
GIJeepN: Tons, 40's, and Stretch GIJOEL Jeep Builds 180 05-23-2019 12:08 PM
96 XJ Axle Swap To Dana 44 - Drivers Side Axle Issue CP30 XJ Cherokee Technical Forum 6 10-02-2018 09:33 PM
What is a CV shaft and why do I want one? Unlimited04 TJ Wrangler Technical Forum 175 02-23-2018 10:17 PM
CrankyGypsy's 2004 Rubicon CrankyGypsy Jeep Builds 33 05-14-2017 09:03 PM
