Need help diagnosing my brakes - JeepForum.com
post #1 of 4 Old 09-20-2015, 04:52 PM Thread Starter
Tman96
2003 grand Cherokee, I have noticed my brakes are getting worse and worse. There are no odd sounds when I brake. But I only start to slow down once I have the pedal over halfway down. It seems like I have to press it down farther and farther every week. Fluid levels are perfect, lines are intact, and the rotors don't appear to have too much wear on them. Please help money is tight and I don't want a mechanic saying I need a whole new system when I don't. Want to DIY if possible.
Tman96 is offline
post #2 of 4 Old 09-20-2015, 06:54 PM
pshivers
2008 KK Liberty
Sounds like you have air in the lines. Have you tried bleeding them?
pshivers is offline
post #3 of 4 Old 09-20-2015, 07:06 PM Thread Starter
Tman96
That is what I was thinking is the problem, if I find any time I'll give it a shot.
Tman96 is offline
post #4 of 4 Old 09-21-2015, 10:43 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Get a couple quarts of fluid and completely flush the system until fluid comes out clear. Also check the adjustment on the rears. As they wear (drum brakes) it can cause the pedal to to down more and increase braking distance. Disregard if you have rear disc.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
