Loss of power in overdrive. - JeepForum.com
 1Likes
  • 1 Post By 222Doc
post #1 of 10 Old 06-13-2021, 09:09 AM Thread Starter
maintman40
4.0 Starts and runs good up thru the gears until 5th gear overdrive, then feels sluggish and won't pull itself.
maintman40 is offline
post #2 of 10 Old 06-13-2021, 09:29 AM
222Doc
222Doc's Avatar
tires over sized?
Jerry Bransford likes this.
222Doc is offline
post #3 of 10 Old 06-13-2021, 03:48 PM Thread Starter
maintman40
31x10.5x15
post #4 of 10 Old 06-13-2021, 04:16 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
So it's got larger than stock tires.
Have you re-geared the axles to compensate for that? If not, what you describe is normal and to be expected. Re-gear the axles if you want to get the power band back to normal.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #5 of 10 Old 06-19-2021, 04:45 PM Thread Starter
maintman40
What's the best gear ratio for 31" tires with a 4.0 and a 5 speed? very little off road driving.
post #6 of 10 Old 06-19-2021, 04:51 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #7 of 10 Old 06-20-2021, 07:43 AM
Pillswoj
Pillswoj's Avatar
2014 JK Wrangler
The 2004 Rubicon came with 31 inch tires and 4.11 gears. You likely have 3.07 gears currently, you might have 3.73s, but if you did you likely would not be complaining.
I would do the 4.11 gears if it was me.
Jeff
2014 2 dr Rubicon
Pillswoj is offline
post #8 of 10 Old 06-20-2021, 10:16 AM Thread Starter
maintman40
Thank you all. You have been a big help!
post #9 of 10 Old 06-20-2021, 10:23 AM
222Doc
222Doc's Avatar
That is a fallacy. gears have to do MORE with STREET. You have a low range that helps with wrong gears for tires size. Can't use that on the street.
222Doc is offline
post #10 of 10 Old 06-24-2021, 10:30 PM
80cj
80cj's Avatar
1980 CJ5
How much power are you losing when in overdrive? Axle ratio, transmission and tire size are all tied together. I would expect a power loss in overdrive. Overdrive ratios turn the drive shaft faster than the engine crankshaft.
80cj is offline
