Liberty wont start - JeepForum.com
post #1 of 4 Old 02-17-2020, 07:53 AM Thread Starter
hydroferg
2006 KJ Liberty
Liberty wont start
2006 Sport - automatic transmission
wouldn't turn over....replaced the battery
old starter tested bad....replaced
new starter doing the same...not energizing
hydroferg is offline
post #2 of 4 Old 02-17-2020, 09:18 PM
pshivers
2008 KK Liberty
Simple checks. Starter relay clicking? 12 volts on the big wire on the starter at all times? 12 volts on the small wire when cranking? Can it start in neutral?
Sent from my Samsung S8+ using Tapatalk
pshivers is offline
post #3 of 4 Old 02-27-2020, 03:18 AM
Kcooks12
Kcooks12's Avatar
Hmm... sometimes it's worth $100 diagnostic fee at a shop to save you the headache. Check relays, crank sensor, cam sensor, connections, ignition switch, neutral safety switch, etc. If you want to do it yourself alldatadiy is a good site for a technical data on testing all those things.
Kcooks12 is offline
post #4 of 4 Old 02-27-2020, 06:55 AM
jtec
jtec's Avatar
2014 JK Wrangler
easy as 1-2-3.
fuses?
12v power at relay 85,86,30?
85 grounding when trying to engage starter?
jtec is offline
