JeepForum.com (https://www.jeepforum.com/forum/)
-   Engines & Drivetrain (https://www.jeepforum.com/forum/f19/)
-   -   Liberty wont start (https://www.jeepforum.com/forum/f19/liberty-wont-start-4387361/)
hydroferg 02-17-2020 07:53 AM
Liberty wont start
2006 Sport - automatic transmission
wouldn't turn over....replaced the battery
old starter tested bad....replaced
new starter doing the same...not energizing
pshivers 02-17-2020 09:18 PM
Simple checks. Starter relay clicking? 12 volts on the big wire on the starter at all times? 12 volts on the small wire when cranking? Can it start in neutral?
Sent from my Samsung S8+ using Tapatalk
Kcooks12 02-27-2020 03:18 AM
Hmm... sometimes it's worth $100 diagnostic fee at a shop to save you the headache. Check relays, crank sensor, cam sensor, connections, ignition switch, neutral safety switch, etc. If you want to do it yourself alldatadiy is a good site for a technical data on testing all those things.
jtec 02-27-2020 06:55 AM
easy as 1-2-3.
fuses?
12v power at relay 85,86,30?
85 grounding when trying to engage starter?
The time now is 01:37 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
