Knock on start up. - JeepForum.com
post #1 of 8 Old 08-25-2019, 07:55 PM Thread Starter
D3GILBERT
Knock on start up.
Looking for some input on my problem. I have a 2002 Grand Cherokee with a 4.7 that has a knock on start up. It only knocks about three times then goes away. The engine runs fines with no other noises. Never heard of a rod knock that went away like this. Can a lifter be that loud until oil pressure builds or possibly a loose torque converter bolt. Any input would be appreciated. Thanks
D3GILBERT is offline
post #2 of 8 Old 08-26-2019, 04:09 AM
80cj
80cj's Avatar
1980 CJ5
What weight oil are you using? Try going a grade heavier.
80cj is offline
post #3 of 8 Old 08-26-2019, 05:32 AM
V8GCZJ
Lack of oil at start up will cause a knock if that is your problem. You may also hear it at the upper rpm's.
V8GCZJ is offline
post #4 of 8 Old 08-26-2019, 09:16 AM Thread Starter
D3GILBERT
Just bought this and was told engine was bad but the only noise is the short knock on cold start. Guess I'll do an oil change with heavier oil like 10w-30 or 40 and see what it does. I have another 4.7 but would need to change the toner rings over and kinda hoping I got lucky with this and won't have to do the work. Thanks.
post #5 of 8 Old 08-26-2019, 09:58 AM
jtec
jtec's Avatar
2014 JK Wrangler
Type of knock, sound, area of sound - lifter, rod, crank as mentioned above but to add -
Sometimes a cylinder can knock first start if it has liquid in cylinder either a injector, head gasket leak.
are you using coolant, a code, extra cranking after long park, fuel pressure drop?
TMI: A Hydro static type issue.
jtec is offline
post #6 of 8 Old 08-26-2019, 10:22 AM Thread Starter
D3GILBERT
No engine codes, runs fine. It is a low pitched knock much like a rod but only lasts for about 3 knocks and is gone, no other noises. I can't answer on fluid loss as I just bought this as a project. Previous owner says it ran fine until this noise started. He immediately stopped driving it and bought a new car. Hoping to get lucky and have an easy fix but will change motors if needed. Bought this real cheap.
post #7 of 8 Old 08-26-2019, 10:48 AM
jtec
jtec's Avatar
2014 JK Wrangler
Run a can of "risolone" an oil detergent - would address any sludge varnish - to easy to ignore as you try to pin this down,
A automotive stethoscope is inexpensive and will really help isolate the area and hopefully the problem.
jtec is offline
post #8 of 8 Old 08-29-2019, 07:33 PM Thread Starter
D3GILBERT
So an update on my Jeep. Oil pan off, spun bearing on 8th rod. Oh well, bought with the plan off replacing the motor anyways. More work but I already had the motor from a Dakota that runs good. Let the fun begin.
