JeepForum.com (https://www.jeepforum.com/forum/)
-   Engines & Drivetrain (https://www.jeepforum.com/forum/f19/)
-   -   Just won't make power (https://www.jeepforum.com/forum/f19/just-wont-make-power-4377763/)
28575r15 11-16-2019 02:52 PM
Put a completely new rebuilt engine into my Jeep all sensors are working correctly engine light is not coming on but when step on the gas it just don't want to go new fuel pump did it compression check today everything is absolutely perfect can't figure out why the machine will not go I step on the gas and it falls on its face replace the intake gasket replace the tb gasket Jeep starts up runs fine backfires occasionally back out of the driveway step on the gas and it just does not want to go no catalytic converter can anyone help
jtec 11-16-2019 04:26 PM
the check engine light should come on @ 3 seconds at every start. Advise yes or no.
what year is jeep and what year engine?
Try accessing codes with your scanner.
Install your catalytic converter.
Check fuel pressure post PSI.
Are you sure CMP was installed correctly - TDC compression?
The time now is 04:01 PM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
