Just won't make power - JeepForum.com
post #1 of 2 Old 11-16-2019, 01:52 PM Thread Starter
28575r15
28575r15's Avatar
Put a completely new rebuilt engine into my Jeep all sensors are working correctly engine light is not coming on but when step on the gas it just don't want to go new fuel pump did it compression check today everything is absolutely perfect can't figure out why the machine will not go I step on the gas and it falls on its face replace the intake gasket replace the tb gasket Jeep starts up runs fine backfires occasionally back out of the driveway step on the gas and it just does not want to go no catalytic converter can anyone help
28575r15 is offline
post #2 of 2 Old 11-16-2019, 03:26 PM
jtec
jtec's Avatar
2014 JK Wrangler
the check engine light should come on @ 3 seconds at every start. Advise yes or no.
what year is jeep and what year engine?
Try accessing codes with your scanner.
Install your catalytic converter.
Check fuel pressure post PSI.
Are you sure CMP was installed correctly - TDC compression?
jtec is offline
