Jeep refuses to go into gear - JeepForum.com
post #1 of 6 Old 11-15-2017, 12:00 PM Thread Starter
TherustedYJ
Okay, so recently I have blew my rear on my '95 yj 4.0 I6. Since then I have replaced the rear and now the jeep refuses to go into gear in 2wd. However, it does go into gear in both 4 low and high. When its in 4wheel drive only the front wheels are being spun though. I have searched all over the forums and have found similar posts but none exact. Any help is appreciated.
Work hard in silence and let success be your noise
TherustedYJ is offline
post #2 of 6 Old 11-15-2017, 10:35 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Put it in gear in 2 high and see if the rear driveline is turning.
If it is, then you have an issue with the rear end.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #3 of 6 Old 11-26-2017, 01:55 PM Thread Starter
TherustedYJ
I know the rear is frozen. I took the rear drive shaft off and still won't go into gear
post #4 of 6 Old 12-04-2017, 07:10 AM
jeepdaddy2000
1971 CJ5
Are you saying the rear output from the t case isn't rotating when 2 high?
Thomas Payne
post #5 of 6 Old 12-18-2017, 07:19 PM Thread Starter
TherustedYJ
Yes
post #6 of 6 Old 12-18-2017, 09:25 PM
mukluk
mukluk's Avatar
Sounds like the transfer case rear output shaft is sheared.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
transfer case , transmission
