JEEP PROJECT: Fuel setup - JeepForum.com
post #1 of 4 Old 03-09-2019, 10:16 AM Thread Starter
Wranglerwild098
Hey All!
So, I have built a Jeep over the past 2 years... unfortunately I had to take about 8 month break (health). I recently looked into my fuel setup and was wondering if someone can explain it to me.
Chevy 350 ... I have the original Jeep TJ gas tank (2001). I was told I can use this, but I need to replace the pump with a hose? I'm confused on this... my engine has all stock parts from '78 camaro (everything rebuilt) so it has a mechanical pump.
I've searched this on this website and others... Can someone help me with this?
should I block the mechanical pump... and just install an external - fuel filter - reg- carb? I was told to stick with the mechanical pump because they are more durable and easy to replace if needed.
Thanks in advance.
Wranglerwild098 is offline
post #2 of 4 Old 03-09-2019, 12:46 PM
fxrsliberty
The fuel pump in the tank will over power the float bowl style carb unless you build a return loop. The Jeep should have the lines already. If you stay with the mechanical pump, your tracking the tank down and finding a way to remove the fuel pump and add a pickup strainer.
Leaving the TJ pump and plumbing the lines is easier.
Sent from my Pixel using Tapatalk
fxrsliberty is offline
post #3 of 4 Old 03-10-2019, 11:58 AM
V8GCZJ
You need to regulate the pressure down also. Keep the oe pump IF it has enough output to feed the V8 and get a bypass regulator. Then you won't have to worry about vapor lock.
https://www.holley.com/blog/post/sel..._for_your_car/
V8GCZJ is offline
post #4 of 4 Old 03-11-2019, 08:47 AM Thread Starter
Wranglerwild098
Alright thanks for the advice. Right now the body is off I’m finishing up lines/suspension.
I’ll just remove the mechanical pump and block it. I’ll try to run the original Jeep pump... I was told on another forum I’ll have to install an external pump to the regulator to the carb.
But I have somewhere to start so I appreciate the info.
jeep 2.5 fuel cut gjoey660 YJ Wrangler Technical Forum 8 03-05-2019 04:24 PM
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3853 02-12-2019 09:15 AM
New Fuel Pump Not Pumping Fuel D3M0N60D WK Grand Cherokee & XK Commander Forum 4 05-20-2018 08:30 PM
Hard Start 5.2 '94 (fuel issues..) JoeTe ZJ Grand Cherokee Forum 8 04-10-2018 06:41 AM
How to install an RB1 navigation unit in a 1997-2001 Jeep Cherokee Country Jeep XJ Cherokee Technical Forum 14 01-21-2018 04:43 PM
