JeepForum.com (https://www.jeepforum.com/forum/)
-   Engines & Drivetrain (https://www.jeepforum.com/forum/f19/)
-   -   Jeep axle ratios problem (https://www.jeepforum.com/forum/f19/jeep-axle-ratios-problem-4435383/)
JC1970 06-14-2021 01:02 PM
I have a 2012 Jeep Wrangler Sahara Unlimited, manual transmission with rear axle ratio of 3.21. It is factory rated with 1,000lbs of towing capacity. The same vehicle with axle ratio of 3.73 or higher is rated with a 3,500lbs towing capacity. Can I change out my differentials for the higher axle ratios? I want the 3,500lb towing capacity.
Side question; can I tow a 3500lb boat with my current version if I'm only towing the boat a mile, maybe 12x per year?
Wheelin98TJ 06-21-2021 01:55 PM
Yes you can change gears to 3.73. Either change gears inside existing axles or swap entire axle assembly. Sometimes people will swap the entire axle assembly because it can be cheaper.
I'd have no problem towing the boat 1 mile with your current setup. 3,500 lbs with the trailer, right?
222Doc 06-21-2021 02:11 PM
legally No. Nothing you add will change the rated amount. Long as nothing happens on the road few will care, if it does then it is a factor in any case.
Wheelin98TJ 06-21-2021 03:27 PM
Kind of.
Insurance covers when you break the law, for example, when you're drunk.
But yes, there is risk you could kill someone and your insurance limits will not cover everything.
How much risk here? 1 mile flat roads? Easy boat ramp? Slow speed limits to the boat ramp?
222Doc 06-22-2021 06:21 AM
The issue is mitigating circumstances . example would be say the incident was not in fact the towing vehicles fault but do to the FACT it is overloaded may play in how this case turns out... anyone gets harmed and now it gets into negligence, perhaps gross negligence.
INS, i never said a word about INS...
The time now is 07:00 AM.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
