Intake manifold removal - JeepForum.com
post #1 of 3 Old 08-08-2019, 12:49 PM Thread Starter
Splinter
1980 CJ5
Having a bear of a time getting my manifold off. I have a jack and pipe across the motor and I am sure I could lift the motor if it was not bolted down. I tried driving thin putty knife between flanges and using a long pry bar on exposed edges. No luck. Maybe if I leave the jack on overnight it will break free. You can see the 2inch as tubing bending.
047FB633-1C54-41E2-BC18-454AFC335831_1565286465817.jpg   7B209932-101E-4BCA-9A08-32B4606BAB72_1565286525654.jpg
Splinter is offline
post #2 of 3 Old 08-08-2019, 04:28 PM
Fourtrail
1974 CJ6
dead blow hammer with some good hits. if oy want to continue to try to remove it by lifting, pull from one end/corner and once you break the seal, it should peal up easier.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #3 of 3 Old 08-08-2019, 06:32 PM Thread Starter
Splinter
1980 CJ5
That worked. Should have thought of that myself. Thanks
Splinter is offline
