LinkBack | Thread Tools |
Front diff rebuild
Hey y’all. Got a whiny noise from front diff. I will be looking into replacing all bearings. Along with Ujoints on output shafts to the wheel hubs. The diffs are Dana 8.25 (only have rear locker) they came off a 99 liberty and are on my 95 XJ now. All the work was done by the previous owner. ( he knew what he was doing) I have looked into a few things on the whole process but would prefer some input from y’all. Any hint tips videos to follow would be awesome. I will get my ***** together and get pics and more info posted. I figured I throw this out here.
Cheers!~
Cheers!~
Sponsored Links | |||
ball joints while its apart perhaps. Though replacing the bearings tends to be more work then it appears.
Yeah. I will be doing them as well. Along with new brake pads and rotors. Any tricks for the U joints on the drive shafts? I did the ones coming from the transfer case (main shafts) both front and rear. Same process for the the axle u joints??
If you end up with any specific questions I can try and offer some advice. I just finished rebuilding my Dana 30 with all new carrier and pinion bearings, seals and a ring/pinion swap and setup. All in all it wasn't too bad but you will need some specific tools. The biggest hurdle is the carrier and pinion bearings. You pretty much need a shop press to do the job correctly. I would not recommend hammering them on.
Also, those are probably not from a Liberty. The Liberty used IFS. Do you have a picture of the axles? What makes you think they are swapped? I'm pretty sure that the Chrysler 8.25 was a factory axle in 1995.
You fix the Jeep, the Jeep fixes you.
It's a Chrysler 8.25, not Dana.
Just got the bearing kit in the mail. The front diff is a Dana 30. The rear is a 8.25. The 95 came with drum breaks OEM, mine had been converted to disk breaks. From what might be a 99 liberty axle. Or a 99 Cherokee!?? If that makes any sense. I am stuck as for what rotors I will need.
As for the front diff I will start this week. Do I need to disassemble the drive shafts? Ball joints? Hub? To romove them from the diff? Are there C clips in the front diff?? Lol (rookie questions)
All my questions have been answered. Just had to put in the time and figure things out as I go. Putting the diff back together today. Hope things turn out good.
Hey there. I have completed the job of putting new bearings in. After a few try’s that is. I seem to be stuck with pinion pre load. The rebuild kit I got only came with cup shims for the inner pinion bearing. It also came with ones to use on the outer, but I did not get any to adjust pinion preload. ( I kept and used the old ones) but it seems it just not enough space. I loaded the nut to 200ft/lbs and noticed the bearing load was high and a lot of heat generated after driving for a bit. ( hot as in fresh brew coffe). I have adjusted inner shims to get max .010 backlash on the gears. But can’t go much more if at all. The carrier is set as for shims and I do not want to redo them. Is there a place that sells just the pinion preload shims? Or??? They no longer use crush bearings. (Dana30).
Any help is greatly appreciated!!
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Posting Rules | |
