front diff problem! i think?? - Page 2 - JeepForum.com
post #16 of 27 Old 08-17-2011, 02:56 PM Thread Starter
herb97tj
Yes true very good point. I guess I shouldn't jump the gun either n test it.out first. Thank you guys for all the help. Now i just gotta find a good mud pit or off road area where I can take.my.jeep
herb97tj is offline
post #17 of 27 Old 08-17-2011, 03:04 PM
mdm
Farm Wheeler
Originally Posted by herb97tj View Post
I still haven't had a chance to test out the 4wd in dirt or mud but some people are still telling me that my wheels should not be doing that on the road? I don't know I'm confused.
Quit putting it in 4wd on pavement. Get it off the hard top and try 4wd and you will see that the folks here are telling you the straight facts. As far as the some folks that are telling you that your "wheels should not be doing that on the road", please refer to my signature and keep it in mind when you are listening to "some people".
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #18 of 27 Old 08-21-2011, 01:19 PM Thread Starter
herb97tj
hey guys i took my jeep out the other day n had the chance to play in some dirt. other than the fact that i need new front tires it did great. so i would like to say thank you for all the advice but now i have one more question. so when i was done i tried to put it back into 2wd n it would not go, now i know what your gonna say could be a broken or loose cable or link i think thats what its called but as i said before the whole 4wd is new to me so any advice on how to fix this would be great. thank you.
herb97tj is offline
post #19 of 27 Old 08-21-2011, 01:54 PM
purplepig
purplepig's Avatar
are you in neutral?
purplepig is offline
post #20 of 27 Old 08-21-2011, 04:08 PM Thread Starter
herb97tj
You mean when I shift out of 4wd? Yes. Neutral on the transfer case no
herb97tj is offline
post #21 of 27 Old 08-21-2011, 04:27 PM
JeepinJarhead03
is it grinding when passing N to go back to 2H or is the linkage binding up and not wanting to go back to 2H you mentioned you had trouble getting it back to 2H earlier in the thread prior to the test in the mud
JeepinJarhead03 is offline
post #22 of 27 Old 08-21-2011, 05:30 PM
kg4kzv
1995 XJ Cherokee
From 4lo to 4hi you have to Stop shift the transmission into Neutral. I have found on my XJ that going from 4hi to 2hi it was best to be rolling but not accelerating or hard deceleration in gear and slowly shift into 2hi.
If it grinds don't force Kill the engine see if it will shift smoothly then. You might need to adjust the linkage.
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #23 of 27 Old 08-21-2011, 06:31 PM Thread Starter
herb97tj
It doesn't grind when I shift the transfer case n to be honest I cannot remember if I had the tranny in neutral so I'll make sure to do that. N check the linkage. Thanks for the help
herb97tj is offline
post #24 of 27 Old 08-23-2011, 06:58 PM
Oldcraneguy
1982 CJ7
I hope you dont have the same problem I do...I was pulling my front diff cover to reseal it and found that it had 3.31s--welded, the backs got 3.54s open...so far
Oldcraneguy is offline
post #25 of 27 Old 08-25-2011, 07:53 PM Thread Starter
herb97tj
O God. How did you fix that
herb97tj is offline
post #26 of 27 Old 08-25-2011, 09:53 PM
husbandjw
Sir, you need to jack up the jeep and count your driveshaft rotations vs. Your tire rotations. It sounds like you have a set of mismatched gears. You should be able to drive the jeep just fine (within reason) on pavement. Unless someone has welded the spider gears or installed a full spool in the front end it should drive down the road. If someone had welded the gears you would know already because you would barely be able to turn and the front end would hop and skip and chirp even in two wheel drive. If the gear ratios match... Remove the front driveshaft and try putting it in four wheel drive. If it is still acting weird you have a transfer case problem.
husbandjw is offline
post #27 of 27 Old 08-27-2011, 05:03 AM
Oldcraneguy
1982 CJ7
I only use 4wheel in the mud/sand, and only when I need it.. gonna replace both axles as soon as $ permit..OCG
4x4 not working , 4x4 problem , front differential
ZJ Smokin Hot Front Diff and Hot Rear Diff biggered Engines & Drivetrain 6 10-23-2010 04:37 PM
ready to pull my hair out: diff problem bustednuckles Engines & Drivetrain 0 06-05-2009 12:13 AM
Welding front diff? GatorsUF General Jeep & Off-Road Equipment 7 10-02-2008 04:29 PM
Front Diff Leaking Dudewayne Engines & Drivetrain 3 05-15-2007 12:15 PM
Diff. Problem SpikeSpeigel Tires & Wheels 10 07-11-2003 10:52 AM
