FAQ - My gas mileage sucks - Page 7 - JeepForum.com
 1Likes
post #91 of 108 Old 10-17-2015, 03:51 AM
mybabyjasper
My 96 Jeep Grand Cherokee Laredo, (4.0L/straight 6; 198,000miles) has been having issues. I've had a random misfire for a long time now (cylinders 2 & 3), and thrown codes about the O2 sensor but no pressing issues. Then I started smelling gasoline randomly and not constant. Well I got rear-ended and they bent my tailpipe just a bit. Now my jeep has a super rough idle, < 9mpg, and is not shifting smoothly. It is also coming close to stalling when idle now. I replaced fuel injectors 1, 2, 3 and is still doing everything and rapidly getting worse. When I unplug the replaced fuel injectors, it doesn't have the rattle - there's no change. When I unplug 4, 5, or 6, it shows the change. What is wrong with my Jeep???
mybabyjasper is offline
post #92 of 108 Old 10-18-2015, 09:31 PM
1outlaw
I am no expert at your '96 but I would imagine folks would need more info to help- here would be questions I would think would need answering;
1) Did the codes go away with the new injectors?
2) What were/are the codes? (cyl misfire only?)
3) Have you tried a full reset of the ECU by battery disconnect- if so what was the result?
4) After getting rear ended did you check to make sure you do not have an exhaust leak from the heads back to immediately behind the O2 sensor?
5) O2 sensor changed- if so- when?
6) Have fuel pump pressures been checked?
7) Spark plugs and wires changed when? (have you run it in total darkness to watch for spark leakage- if so did you spray it to simulate humid condition?)
8) when does condition appear? When hot? When cold? When accelerating/climbing a hill? Etc.
That is what comes to mind tonight- I am sure others will have better questions.
1outlaw is offline
post #93 of 108 Old 11-03-2015, 10:31 AM
Penguin_Jeep
2006 WK
Originally Posted by jspb16 View Post
i think i am getting like 12 or 13 mpg! ugh...
I've had mine as high as 38.5 mpg (UK imperial) on the freeway/motorway
Normal motorway is 32-36 at around 65
Typical city driving returns 23-28.
Mine is a 3.0 CRD Diesel Grand Cherokee 2005.
Mine has a K&N panel filter and I user synthetic oil, Amsoil in front, rear and in the T'case. Running slightly taller and wider than
stock tyres (aka tires).
Penguin_Jeep is offline
post #94 of 108 Old 02-03-2016, 11:41 AM
erndizz
yeah i averag elike 15 depends on my driving
erndizz is offline
post #95 of 108 Old 08-22-2016, 09:48 AM
JeepGirlPA
Gas mileage is also affected in winter by the additives put in gasoline to keep it from drawing in water and freezing. I usually put in 1/4 bottle isoheet when I top up and it brings back the fuel mileage a little.
JeepGirlPA is offline
post #96 of 108 Old 08-30-2016, 10:38 PM
97TJNamedJill
my 97' TJ 4.0 gets around 17mpg city and 18.5 combined but I dont really do a lot of highway driving. Ever since I put the stainless exhaust on and used marvel mystery oil over time the mileage improved. I have a 2.5'' lift with 31s and 3.07 gears. Very rarely do I use 5th gear. If Im going 70+ I can use 5th but I do around 40 in 3rd gear at around 1,600 rpm. I wonder if 17 mpg city is good for my setup.
97TJNamedJill is offline
post #97 of 108 Old 02-03-2017, 12:36 PM
barkle
"marvel mystery oil"? what, exactly, is in that stuff?
barkle is offline
post #98 of 108 Old 02-04-2017, 07:17 PM
97TJNamedJill
It's an oil additive that's been around for decades, it really works I put it in all my dirt bikes too.
post #99 of 108 Old 02-07-2017, 04:54 PM
Charley3
It's a thin-weight super HIGH detergent oil (almost like a solvent) that lubricates a little and cleans alot. If you put a little in gas it cleans your top-end. If you put a little in your motor oil it cleans bottom-end.
However, be careful cleaning bottom-end because if a large chunk of carbon comes loose in your motor oil, it can damage bearings. If you use it in bottom-end, make sure you have a new oil filter when you add MMO and then change filter again after 100 miles in case any chunks of carbon got into oil.
My preferred way to clean bottom end is to use synthetic motor oil. All brands of synthetic motor oil have high detergent.
Warning: I often edit my posts a few times to get them complete or correct errors.
Charley3 is offline
post #100 of 108 Old 02-07-2017, 05:07 PM
Charley3
I think you're doing well.
It's good to learn of Isoheet. I might try that.
Re Marvel Mystery oil and other methods of cleaning topend of engine...
My mechanic used a professional product-system-machine to clean my engine's topend. It's called Motorvac. Same concept as Seafoam, but I think Motorvac is more effective. Marvel Mystery oil added to gas tank is an old school way to clean topend of engine. I learned of using MMO to clean top-end when I was in auto-shop in school 30+ years ago. My grandpa used it 60+ years ago. MMO is old school, but it still works today. If I was going to use a DIY method of cleaning top-end, I'd use Marvel Mystery oil because I think it's safer than Seafoam. However, I think Motorvac is most effective and worth the cost ($125) that I paid my mechanic.
My gas mileage is pretty good for a Jeep 4 liter engine with auto tranny, 1.5" lift, 30x9.5R15 AT tires, and 200 lbs skidplates. Driving at 60 mph on level highway I get 25 mpg on a good day in Summer, or 23 mpg on a bad day. It averages 24 mpg in Summer. I haven't tested my Winter gas mileage. So I don't know what Winter mpg is, but I think it's OK because I don't have to fill up very often.
Here is a thread I made that explains things I did to improve gas mileage of my 99 Cherokee XJ. https://www.jeepforum.com/forum/f11/m...5-ats-1551782/
Charley3 is offline
post #101 of 108 Old 05-08-2017, 09:10 PM
bszymborski
Interesting
bszymborski is offline
post #102 of 108 Old 06-06-2017, 05:03 PM
AMcMartin82
2014 WK
With a 5.7L V8 GC, i get around 16L/100km in the city during rush hour. But surprisingly, it drops REALLY low on the highway. On the highway i hover around 8L/100km, which is insane because my Subaru WRX would get 7L/100km at best and this GC is a heck of a lot bigger and heavier. We haven't taken an official road trip with it yet though, so i'll be interested to see how far i can get on a single tank of fuel.
AMcMartin82 is offline
post #103 of 108 Old 06-14-2017, 03:09 PM
Donuts31
24 mpg on highway, 15 mpg towing ATV trailer, 18 mpg towing snowmobile trailer in winter. 2007 WK CRD.
Donuts31 is offline
post #104 of 108 Old 08-01-2017, 05:35 PM
40gearhead
2016 JK Wrangler
40gearhead is offline
post #105 of 108 Old 09-29-2017, 03:09 PM
Clarence_Beeks
12.5 MPG all around avg, for a 2006 TJ, auto. 4" lift and 33" (KO2's). 53K miles on her too.
Clarence_Beeks is offline
faq , gas mileage , improve mpg , miles per gallon , mpg , poor gas mileage
bfg mt km mileage and tsl radial mileage epeck87 Tires & Wheels 1 03-29-2009 09:53 AM
Cragar sucks tjsooley Tires & Wheels 63 08-21-2006 09:50 AM
JL audio sucks!!! orangez Audio, CB & Ham Radios, GPS, & Electrical 12 10-06-2004 01:05 PM
RE Sucks TJ2000 Tires & Wheels 3 12-24-2003 01:43 AM
Help!!! My sterio sucks!!! myfirstcar5.9 Audio, CB & Ham Radios, GPS, & Electrical 9 05-22-2003 12:41 PM
