Exhaust - Best choice for V8 - JeepForum.com
post #1 of 9 Old 09-24-2021, 08:40 AM Thread Starter
Lerxst
What is the best choice for an exhaust after having done a V8 swap on an older YJ (355 CID fuel inj in my case)?
Single or Dual exhaust (i.e. single muffler w/2 into one and one outlet) or True dual exhaust (i.e. 2 mufflers)?
What size should inlet/ outlet be? (everyone says 3" in/ 3" out. True?)
Best choice in mufflers? Flowmaster? Magnaflow? I realize this maybe a personal preference.
Any help/ opinions would be appreciated.
Thanks.
Lerxst is offline
post #2 of 9 Old 09-24-2021, 04:37 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I fabbed the front half on my own as single pipe ending in 2.5" into the cat. I picked a 2.5" in and out cat, and added a Magnaflow YJ 'catback' 2.5" kit from Summit. It took some finesse to get it all in, but it's nice. Flowmaster is to loud in my opinion.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" Patagonia M/Ts, AX15, NP231+4:1+SYE+2LO, York OBA.
Web Admin for
JeeperDon is offline
post #3 of 9 Old 09-25-2021, 01:18 AM
80cj
80cj's Avatar
1980 CJ5
On the same topic, whats a nice quiet muffler for a CJ-5 without a cat converter?
80cj is offline
post #4 of 9 Old 09-25-2021, 03:37 AM
kmiller7351
1981 CJ7
The guy who will put on my exhaust reccomended flo pro twisters. I am waiting on my order. Fenderwell headers with duel pipes going out back.
kmiller7351 is online now
post #5 of 9 Old 09-26-2021, 06:08 AM
V8GCZJ
You can achieve the same amount of performance from both depending on what diameter pipe you use. Headers with a X pipe then duel i prefer but depends on your preference space and cost.
Actually going to large will ruin performance rather than increase it. The length of exhaust also factor in.
Question is "best" for what? Price, performance, size or sound. Performance wise straight through is best. Chambered you can get good performance with good sound(not to loud) depending on what muffler you choose.
V8GCZJ is offline
post #6 of 9 Old 09-26-2021, 10:37 AM Thread Starter
Lerxst
Thanks for your response. So It looks like I may do the following.
True dual exhaust (i.e. 2 mufflers) with 2 1/2" in and 2 1/2" out.
My primary goal for muffler selection is Sound. Right now I have a Flowmaster 40 but I'm not happy with it. This could be possibly be because the guy who did the work was a less than capable mechanic (and I use that term lightly). He did not have the ability to bend pipe so he took the path of least resistance. Today I have shorty headers that dump into a collector (i.e 2 inlets) than exit one outlet. That goes to the single inlet on the Flowmaster and exits one outlet on the same muffler.
Like the idea of a chambered mufflers, but whose mufflers are chambered? Flowmaster?, Borla?, Magnaflow?
Lerxst is offline
post #7 of 9 Old 09-26-2021, 10:50 AM Thread Starter
Lerxst
pics
M[ATTACH]flowmst40.jpg[/ATTACH] set up
Lerxst is offline
post #8 of 9 Old 09-27-2021, 11:12 AM
Fourtrail
1974 CJ6
Your biggest issue there is likely drone and resonance in the Jeep? You probably just need a tailpipe that exits the vehicle pointing out to the side behind the rear tire. this will take care of the drone inside the jeep and also take care of any fumes. What is currently there actually looks good, quality welds, and a band clamp so you can easily remove the front pipe section if you need to do any work to the motor, i.e. drop the oil pan. A 40 series flowmaster is a loud muffler, I am a bigger fan of the 50 or 60 series flowmasters, but they can get big and you have limited room under a YJ.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
post #9 of 9 Old 09-27-2021, 11:24 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
2020 J-Series Truck
Personally I like the Flowmaster 40 series. A little loud, but they sound great!
Wheelin98TJ is offline
