Error P0452, EVAP Pressure Switch A Stuck Closed - JeepForum.com
post #1 of 4 Old 09-27-2021, 01:15 PM Thread Starter
TonyMart
When I measure voltage to the EVAP purge solenoid, either ignition on or engine running, it reads 0 volts.
By EVAP purge solenoid, I mean the valve in the engine compartment. Hope I have the name right.
I have had other error, but after resetting I get P0452.
If I connect the valve directly to the battery, it clicks and lets air through, other wise its closed.
No idea what is wrong.
Tank you,
Tony
TonyMart is offline
post #2 of 4 Old 09-27-2021, 01:46 PM
jtec
jtec's Avatar
2014 JK Wrangler
what color is your car?
Might also tell us year, model, engine, and ALL codes. .
jtec is offline
post #3 of 4 Old 09-27-2021, 11:06 PM Thread Starter
TonyMart
Tank you,
Tony
Update:
I checked for leaks using a smoke tool and didn't find any. The Purge Solenoid seams to be working. It opens and closes when I apply 12v to it.
The Fuel Vapor Leak Detection Pump, I replaced with a new one and didn't fix the problem.
TonyMart is offline
post #4 of 4 Old 09-28-2021, 08:47 AM
jtec
jtec's Avatar
2014 JK Wrangler
X2 year model engine
jtec is offline
