Engine stutters with AC on - JeepForum.com
post #1 of 3 Old 05-04-2021, 08:47 AM Thread Starter
StreetJeep99
I have a 99 GC with the 4.7. It generally runs like a top but when I turn on the AC the whole vehicle bucks quite hard as the AC is engaged. Then the vehicle will stutter, buck, and fall on its face when I accelerate. Jeep will die at idle with AC on.
CEL also came on. Code p1391. Intermittent crank or cam signal.
Before the CEL was read I was anticipating a misfire on one coil or a weak alternator. However, now I am a little confused .
StreetJeep99 is offline
post #2 of 3 Old 05-05-2021, 11:22 AM Thread Starter
StreetJeep99
Any opinions?
post #3 of 3 Old 05-05-2021, 11:35 AM
jtec
jtec's Avatar
2014 JK Wrangler
you do NOT get a DTC P1391 until the AC is selected?
As for the AC - of course checking the belt, tight do you see it dragging ie compressor seams to stall and belt slips.
A AC check esp the HI side readings... will need a set of AC gauges.
Try this - unplug the AC compressor select AC there shpild be no difference yes no?
AC causing a low RPM - look at the IAC - cleaning esp the air bleed and pintle. There is NO P0505?
jtec is offline
