Engine Question(s) - JeepForum.com
post #1 of 10 Old 01-31-2020, 12:05 AM Thread Starter
vincentjones1
Engine Question(s)
Hello everyone. I am new to this group. I have a couple of question(s) concerning my engine. The engine has 203500 miles on it. Recently I have been experiencing the following:
- Bad gas mileage
- Intermittent loss of power while driving
- While driving, the car feels jerky and rough
- Some smoke (O2 sensors are new; getting a lean code from the ODB2)
- RPM gauge has been acting erratically
- On the plus side, still idles great
My regular mechanic has been working on the Jeep for about 7 years and he cant locate the problem.
I took the Jeep to the dealer and they ran a diagnostic test (185$). They got the same lean code as my mechanic. That was it. The rest of the diagnostic test didnt show anything (the exception being low compression on #1). Didnt address the driving issue, even after they test drove it. Complete waste of money.
My question is this: Has anyone reading this experienced these things with their Jeep, specifically this engine? Any and all answers or guidance would be appreciated.
Thanks.
Vince
vincentjones1 is offline
post #2 of 10 Old 01-31-2020, 12:17 AM
mukluk
mukluk's Avatar
Might help to fill folks in on what year and model Jeep we're talking about, what engine, what were the compression readings, and what specific fault code you're getting.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 10 Old 01-31-2020, 04:49 AM
V8GCZJ
This still amazes me that people ask questions and NO vehicle/engine info? Just don't get it! We don't all have these...
V8GCZJ is offline
post #4 of 10 Old 01-31-2020, 09:53 PM Thread Starter
vincentjones1
2007 JK Wrangler (4 door)
Engine: 3.8
Cylinders:
#1: 60PSI
#2: 65PSI
#3: 70PSI
#4: 60PSI
#5: 70PSI
#6: 65PSI
Lean Code(s): P0171 and P0174
That should cover it. And I hope that helps.
post #5 of 10 Old 01-31-2020, 10:03 PM
Arty McGeep
Arty McGeep's Avatar
If your compression readings were that low, your engine wouldn’t even run at all. Sorry. Try again.
Arty McGeep is offline
post #6 of 10 Old 01-31-2020, 11:42 PM
mukluk
mukluk's Avatar
P0171 and P0174 show both upstream O2 sensors are reading lean. Factoring in the poor fuel economy as well, I'd say chances are quite good you either have a bad exhaust leak near your upstream sensors that's causing a false lean condition, or you have an aftermarket "performance" chip installed that's messing up the upstream sensor signals.
The compression figures you posted are quite suspect. As noted, if they were truly that low it's unlikely your engine would run or at the very least it would be burning so much oil you'd think it was a two stroke.
Pull your sparkplugs and have a look at the portion that goes in the combustion chamber. Do they look black and oily, black and sooty, tan or light grey, or are they white?
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #7 of 10 Old 02-06-2020, 09:48 PM Thread Starter
vincentjones1
After speaking with a few mechanics, they were in agreement with what you said. If the compression readings were that low, the jeep would have a very rough time of operating. The dealer did the compression test. If it was that bad, why wouldnt they have said anything? I will have to deal with them later.
Anyways, what can anyone tell me about the electronic throttle control system? If it is good or bad, other than the warning lkighht coming on.
post #8 of 10 Old 02-07-2020, 05:36 AM
jtec
jtec's Avatar
2014 JK Wrangler
electronic throttle, the symbol is illuminated, SO you will need to scan for codes.
X3 on those compression #s something is wrong with them...do over suggested.
the p0171 p0174 as mentioned LEAN some suggestions above - a scanner looking at live data would be a faster glimpse and time wise quicker than typing this reply
jtec is offline
post #9 of 10 Old 02-10-2020, 10:47 AM Thread Starter
vincentjones1
quicker than typing this reply <img src="https://www.jeepforum.com/ubb/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
I replaced the electronic throttle control module but it is still running like crap. Plus the flashing check engine light came on this morning.
post #10 of 10 Old 02-11-2020, 07:09 AM
jtec
jtec's Avatar
2014 JK Wrangler
what codes are showing?
Why did you replace 'module' ?
jtec is offline
