Engine Overheating - JeepForum.com
post #1 of 4 Old 01-25-2012, 11:28 AM Thread Starter
laxchris7
Engine Overheating
I have a 2003 Grand Cherokee and I have had some issues with the engine overheating when the car is in park, or stopping at a red light, and similar situations. Im in the marine corps, and recently moved to jacksonville nc. Before I moved (literaly the same week) I had to have the radiator and relay replaced because the radiator blew while my buddy was dropping it of at the airport for me. Cost me $900 to get fixed, and now im running into the same problem, and i cant take it back to the dealership who fixed it because i'm 750 miles away. any ideas/suggestions?
laxchris7 is offline
post #2 of 4 Old 01-25-2012, 07:20 PM
Yams
Check to see if the dealership put the thermostat in backwards
Yams is offline
post #3 of 4 Old 01-26-2012, 01:06 PM
herbiehind
fanworking properly? while moving air is forced over radiator fins . but sitting ,it needs fan . obviously the waterpump/thermostat is working .
herbiehind is offline
post #4 of 4 Old 02-06-2012, 04:48 PM
Flinticus
Yes, thermostat's seem to be a cheap culprit of many overheating problems, maybe b/c of the prolonged non use could be causing it to sieze, maybe use one of those prestone additives that helps lubricate everything in the cooling system could help
Flinticus is offline
Help! Overheating Goza543 Engines & Drivetrain 5 09-28-2011 09:00 PM
Engine overheating, but not hot.... CarolinaZJ Engines & Drivetrain 1 06-16-2011 07:43 AM
Overheating!!! 90cherokeeJB Engines & Drivetrain 0 03-16-2011 10:22 PM
2.5L V6 overheating. . .tried everything I could think of??? atomicjoe23 Engines & Drivetrain 5 03-29-2008 10:59 AM
4.0 overheating eclipse27 Engines & Drivetrain 13 08-20-2006 07:52 AM
