Engine Mounts - JeepForum.com
post #1 of 7 Old 07-27-2020, 11:09 PM Thread Starter
achesonj88
Engine Mounts
Hello,
I have a 2000 Jeep Grand Cherokee. I am trying to put a 4.0L engine out of a early 2000's Jeep Wrangler into the Grand. The bolt holes on the engine out of the Wrangler, don't line up with the engine mounts on the Grand, and the engine brackets off of the Wrangler don't line up with the bolt holes on the frame of the Grand.
My questions are: Is this swap possible without some serious fabrication work? Has anyone done it? And lastly, is there a company that someone may know about that manufactures engine mounts for this kind of thing???
Thank you for any and all input.
achesonj88 is offline
post #2 of 7 Old 07-28-2020, 07:30 AM
Goatboy4570
Goatboy4570's Avatar
1983 CJ7
Engine swap grand chero
So im guessing the GC had a V8 and your dropping in a 4.0 six, as far as i know the 4.0 was an option on the grand (it was in the late 90's anyway, cause i have one from a 96 grand) so factory motor mounts should be available from the wrecking yard ?
Goatboy4570 is offline
post #3 of 7 Old 07-28-2020, 09:42 AM Thread Starter
achesonj88
Re GC
No, The GC had a 4.0 inline 6 in it as well. So both engines were are 4.0. But the one out of the wrangler has a different mounting bracket and bolt hole pattern.
post #4 of 7 Old 07-30-2020, 01:07 AM
Goatboy4570
1983 CJ7
Chero and wrangler blocks dif ?
I've always assumed the 4.0 and 4.2 had never changed the block to motor mount bolt pattern going all the way back to the CJ5/7 days.
I have a pile of motor mounts in my shed and they all have the same 3 bolt pattern on the engine side, at least i think they do just lookin at em, the frame side tho there are sliit variations. I could do some measurements as i do have a 2000 wrangler block im working on right now for my 83 cj7.
I will say the 2000 block does not have everything drilled and tapped for me 83 accessories but the bosses are still cast there to allow me to drill and tap for backward compatibility.
It would be great if you could up load a couple photos ?
post #5 of 7 Old 08-01-2020, 09:33 PM
rjbruzan
Try looking into BrownDog motor mounts. There will be other items that wont bolt up also. Perhaps A/C and alternator.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #6 of 7 Old 08-04-2020, 07:46 AM
YJB88
What I have read says that the 2000+ WJ/TJ engines should interchange, XJs will not. I ran into issues long ago working on a getting a 2000 WJ 4.0 into a 88YJ using the 4.2L brackets. There were some differences in the mounting bosses that would not allow the brackets to mount to the motor. Have you checked the block casting numbers to verify that the engine is not older?
Following Ron's advice, I have seen others suggest contacting Brown Dog for motor mounts as well.
Edit:
Cant post links yet, but search the forum. There is some good information here on the differences.
YJB88 is offline
post #7 of 7 Old Yesterday, 02:43 PM Thread Starter
achesonj88
Re All
Hello,
First I would like to thank everyone who replied to my post for your comments and advice.
Secondly, I have decided to go another route as I need a vehicle for my family and need something a little quicker than trying to spend lots of time messing with the jeep. Someday I may get to mess around with the doing a rebuild. Which is what I wanted for this, but time and need are out weighing that right now.
Thanks again.
