Engine Issues - JeepForum.com
post #1 of 7 Old 02-04-2012, 07:47 PM Thread Starter
nkihn1987
Engine Issues
Hopefully someone out there can help...
I just bought a TJ the other day. After I brought it home, a bunch of problems cropped up.
The engine does not reach operating temperature, only the first tick (150ish?) on the gauge. There are no apparent coolant leaks. There is a bit of white smoke (could be vapor?), however the coolant level is not changing. I'm assuming I should replace the thermostat, but if this is something worse I'd rather not bother... I should also point out that warm air will blow out of the vent if turned on.
Oil pressure is 40 on a cold start. After warming up (as warm as it gets) the check gauge light comes on and the pressure drops to 0. I replaced the sending unit and the same issue continues to occur...
Any ideas? Thanks!
nkihn1987 is offline
post #2 of 7 Old 02-05-2012, 08:49 AM
Jason
Jason's Avatar
Could be a thermostat stuck open keeping the engine too cool. I would try that first, with some new coolant.
I wouldn't mess with the oil pressure thing until you get the cooling system squared away. However, I assume you've already put in new oil and filter?
Jason is offline
post #3 of 7 Old 02-05-2012, 11:55 AM
Flinticus
agreed
I agree w/ Jason, 1/2 the time its the simple things that creep up and bite ya in th a**.... thermostat's only like $5-$10 typically, along w/ maybe using an oil flush w/ the oil change. Next, step.... hope that you don't have to replace gaskets...
Flinticus is offline
post #4 of 7 Old 02-05-2012, 10:55 PM
deputyvaughn
1962 CJ5
I would recommend concentrating on the oil pressure problems first. Get an manual gauge and confirm the oil pressure is dropping at operating temps. If it is you have a serious problem, i.e. main bearings or cam bearings. White smoke is oil burning. My guess on the temp is someone removed the thermostat and it doesn't have one.
Scott
I may get lost....but I won't get stuck....JEEP
deputyvaughn is offline
post #5 of 7 Old 02-06-2012, 06:01 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's an interesting thread on oil pressure .Could be very applicable to an engine that never got up to operating temp for a long time. Ever shined a flashlight in the oil filler hole to see how sludgy the inside of the engine is?
https://www.jeepforum.com/forum/f19/4...fixed-1304679/
cruiser54 is offline
post #6 of 7 Old 02-17-2012, 06:51 PM Thread Starter
nkihn1987
I checked pressure with a manual gauge today. about 50-60 at cold start and warm idle was around 15. is that ok for an engine with 140k on it?
post #7 of 7 Old 02-17-2012, 06:53 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yep. 13 at idle is fine per the FSM.
2002 Jeep Liberty 3.7L Engine Swap to newer 2004 engine 1SickWS6 Engines & Drivetrain 18 07-28-2019 10:48 AM
Iron Duke engine harness issues? 1cj5 Audio, CB & Ham Radios, GPS, & Electrical 0 01-16-2011 06:23 PM
Can a 1984 CJ7 258 engine fit in a 1988 Wrangler laredo with a 258 engine?? xavier27 Engines & Drivetrain 8 10-08-2010 06:42 PM
97wrangler Automatic and 4 cylinder engine. THINKING ABOUT AN ENGINE SWAP AND MANUAL BoatsJeep Engines & Drivetrain 0 11-12-2009 08:01 PM
Engine swap legal issues Nanuq Engines & Drivetrain 0 08-22-2006 09:26 PM
