Elv & escl - JeepForum.com
post #1 of 1 Old 05-09-2021, 12:35 PM Thread Starter
Jfogle01
Elv & escl
Ok, so I'm looking for some help figuring out what exactly the ELV and ESCL are. I'm having issues with a keyfob that I just bought and wanted to do the programming of it via AlphaOBD and was given the flowing warning message:
WARNING!!! After all the keys are programmed, you must run 'ELV Replaced' or 'ESCL Replaced' if the vehicle is equipped with ELV/ESCL. DO NOT RUN ANY OF THESE PROCEDURES IF THE CORRESPONDING HARDWARE IS NOT INSTALLED!! THIS WILL DAMAGE THE WCM!!
WARNING!!! After all the keys are programmed, you must run 'PEM Replaced' in the PEM to transfer new programmed key information from WCM to PEM. Failure to run PEM Replaced will cause improper Keyless Go functionality."
Ant help would be greatly appreciated!! I'm still learning my way thru this Jeep having always been a f250&f350 guy, and any knowledge I can gain would be great!!! Thanks in advance!
Jfogle01 is offline
