Durango axle swap option? - JeepForum.com
post #1 of 25 Old 08-01-2006, 07:44 PM Thread Starter
JasonCherokee
What axles came in the V8 Dakota and Durango? I think I found that they came with a 9.25. What is that comparable to?
1996 XJ Country
RC 4.5" Lift, Black AR wheels, 35x12.50 Super Swamper TSL, RE Hack 'n' Tap with front driveshaft, 4 TJ rear fender flares
1990 Volkswagen Corrado VR6
JasonCherokee is offline
post #2 of 25 Old 08-01-2006, 08:19 PM
EMT
Guest
i dont know what axles they came with but a 9.25 is comparable (just slightly under) a d60.
EMT is offline
post #3 of 25 Old 08-02-2006, 12:56 AM
96JXJ
Guest
My 2000 with the 4.7 has an 8.25. JIM.
96JXJ is offline
post #4 of 25 Old 08-02-2006, 07:41 AM Thread Starter
JasonCherokee
Ya, I saw that the newer durangos with the 4.7 have the Cryco 8.25. But do the older ones with the 5.2 and 5.9 have different axles? Also....what were the axle options for the Dakotas with the 5.2 engines?
Is there another reason why no one uses the axles out of the 5.9L durango's?
1996 XJ Country
post #5 of 25 Old 08-02-2006, 08:32 AM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
The ChryCo 8.25 and 9.25 were both uses on the durango, a quick way to tell the difference is 10 cover bolts = 8.25 and 12 cover bolts = 9.25.
On paper the 9.25 looks nice, 31 spline shafts, 1.8" pinion with 29 splines, 9.25" ring gear...
...the downfall is the short list of lockers...
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #6 of 25 Old 08-02-2006, 08:44 AM Thread Starter
JasonCherokee
Well...looking at junkyard listing I can get a 9.25 open for $450. Is that not a good deal for a strong axle? I mean an 8cyl explorer axle is close to the same cost as the 9.25 or is it way cheaper to pick up? Is there a reason (besides locker availablity) to pick an 8.8 over the 9.25?
Did all explorers 6cyl and 8cyl all come with the 8.8 axle?
1996 XJ Country
post #7 of 25 Old 08-02-2006, 09:11 AM
TellyDSP
Poland and PPV!!!!
I dont know the specs of the Dodge axles, but the 8.8 is the same width as the 35, some come with LSD, and also available in stock Jeep gear ratios, and basically a straightforward swap. Also, they can be had for $200 around here, if not cheaper, and are plentiful with all the Exploders on the road.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #8 of 25 Old 08-02-2006, 09:19 AM Thread Starter
JasonCherokee
Well....$200 is considerably less. I guess that is what I will go with then.
1996 XJ Country
post #9 of 25 Old 08-02-2006, 08:03 PM
TellyDSP
Poland and PPV!!!!
As a start, here are some on car-part starting around 250, in Ohio. I picked the 3.73 axles. Not sure if that's your ration, but I thought it was.
http://car-part.com/cgi-bin/search.c...ey=&userPage=4
-Craig-
95 Rio Grande
07 Ram 1500
TellyDSP is offline
post #10 of 25 Old 05-11-2012, 08:56 AM
grainofsalt
To my knowledge All explorers had the same axle V6 Or V8. You can check the axle code on the door.
http://www.stu-offroad.com/axle/8.8axle/8.8axle-1.htm
http://www.jedi.com/obiwan/jeep/ford88.html
http://www.naxja.org/forum/showthread.php?t=1000520
https://www.jeepforum.com/forum/f11/8...ite-up-530202/
grainofsalt is offline
post #11 of 25 Old 05-11-2012, 02:49 PM
ajmorell
ajmorell's Avatar
Originally Posted by grainofsalt
Dude, this thread is 6 years old....
ajmorell is offline
post #12 of 25 Old 05-11-2012, 02:53 PM
Andywear
Andywear's Avatar
hahahaaaa, not anymore.
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #13 of 25 Old 05-12-2012, 08:30 AM
Griff1918
And to the guy that said the 8.8 is the same width as a d35. You are a couple inches short.
Griff1918 is offline
post #14 of 25 Old 05-12-2012, 08:38 AM
ajmorell
ajmorell's Avatar
The 8.8 is narrower, but not by a couple inches, it's about 5/8 of an inch per side
ajmorell is offline
post #15 of 25 Old 05-28-2012, 02:54 PM
ericksin
ericksin's Avatar
1982 CJ7
I think I'm going to put an 9.25 in my jeep , I keep breaking axle shafts in my Dana 44's (3 times now!!)
A Chry 9.25 is $95.00 at my local junk yard, and its the same bolt pattern
E-Locker http://www.justdifferentials.com/ind...oducts_id=3960
4.88 gears http://shop.cruiserparts.net/index.p...ducts_id=11306
ericksin is offline
Durango Steering Box Swap In A ZJ gunthagunth Technical Articles & Write-Ups 0 08-26-2008 08:36 AM
Axle swap sdozzi Engines & Drivetrain 0 04-18-2008 01:32 PM
D35 axle swap TJ Clay Engines & Drivetrain 1 12-06-2007 09:28 PM
axle swap... BigWaylon General Jeep & Off-Road Equipment 1 05-21-2004 06:39 PM
soa axle swap... I-4 Tires & Wheels 2 04-29-2002 09:50 PM
