Difficulty of Dana 20 rebuild? - JeepForum.com
post #1 of 4 Old 07-14-2016, 07:48 AM Thread Starter
DuckDuckBoom
So my transfer case is leaking out of the rear seal. I got 402001 rebuild kit from advanced adapters.
What Im wondering is how hard is it to install? I've read up on it and seems fairly intensive. I have some tools (basic mechanics tool) but no press or any thing. Would it be something I can do, or should I take it to a shop for this time?
DuckDuckBoom is offline
post #2 of 4 Old 07-15-2016, 10:02 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
You will need to press the bearings off and on the shafts. You may also want to purchase a dial indicator(although it isn't really necessary).
Other than that, it is pretty straight forward.
The duty of a patriot is to protect his country from it's government
Thomas Payne
jeepdaddy2000 is offline
post #3 of 4 Old 07-17-2016, 01:37 PM Thread Starter
DuckDuckBoom
Thank! Do you know if a 1 ton arbor press would work of will i want like a HF hyd press?
post #4 of 4 Old 07-17-2016, 03:15 PM
jeepdaddy2000
1971 CJ5
It doesn't take a lot of pressure to get the bearings on, the issue is pulling them. You will need a bearing splitter or puller to get them off.
Thomas Payne
dana 20 , rebuild , transfer case
