Did I just melt my engine? (Diagnostic Help) - JeepForum.com
 2Likes
  • 1 Post By mukluk
  • 1 Post By K.Greenhorn
post #1 of 5 Old 09-29-2019, 05:37 PM Thread Starter
K.Greenhorn
Hey, strangers.
This seems like a pretty solid community, I'm learning from reading but wanted to ask a very pertinent question. My '94 XJ broke down on the freeway a while ago. The radiator blew going up a hill, I threw more coolant in and pushed it till it died two more times and wouldn't start. I got around to replacing the radiator, filled the new system with coolant, charged the battery... but when I go to start it seizes. Could I get some help diagnosing? I might have melted part of the engine. If it's not obvious... I'm a total greenhorn at this.
Thanks in advance!
K
K.Greenhorn is offline
post #2 of 5 Old 09-29-2019, 05:49 PM
pshivers
2008 KK Liberty
Take out the spark plugs and turn the engine over by hand via a socket on the crank pulley. See if you bent or warped something inside causing a bind. Then investigate deeper if need be.
Sent from my Samsung S8+ using Tapatalk
pshivers is offline
post #3 of 5 Old 09-29-2019, 05:52 PM
mukluk
mukluk's Avatar
You overheated the engine to the point of dying multiple times and now it seizes when you try to crank it over. As a result, diagnosis is now going to consist of pulling the engine apart to inspect and measure things to see what is damaged and if it's repairable. Next time call a tow truck or a cab.
dln1962 likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #4 of 5 Old 10-05-2019, 12:03 PM Thread Starter
K.Greenhorn
Thank you! Time to pay life some tuition.
dln1962 likes this.
post #5 of 5 Old 10-12-2019, 05:54 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Spun crank bearing(s) would be my remote diagnostic scientific wild azz guess
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
