d30 & d44 ok for 35" tires? - JeepForum.com
post #1 of 7 Old 08-28-2006, 01:33 PM Thread Starter
JeepMKcomin
the topic, are the stock d30 front and d44 rear ok for 35" tires?
06TJ Silver Ruby - REBB w/DT3000s, Quick Discos, Superwinch EPi9.0, Warn engine skid, PS Box Skid, Diff Guards, IPF Lenses, x51s soon
92YJ White - Slight Shackle Lift w/30x9.5 BFG ATs, Custom Beefy Bumpers
06TJ Khaki Sport - Traded in
JeepMKcomin is offline
post #2 of 7 Old 08-28-2006, 01:46 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
They will do just fine. 35's would be the max for reliability on that front D30. A light weight 36-38 tire for the D44 out back.
HTH
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #3 of 7 Old 08-28-2006, 01:47 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
2020 J-Series Truck
Usually yes.
But it depends on your driving style and how you'll be using your rig.
Wheelin98TJ is offline
post #4 of 7 Old 08-29-2006, 08:06 AM
JJs99TJ
Guest
Originally Posted by Wheelin98TJ
Usually yes.
i agree, a couple local guys have broken D44 shafts with 35's
based on their extremely aggresive driving styles and have since
upgraded to alloys, and then there are people running 35's and
37's with no problems, just dont over do it
JJs99TJ is offline
post #5 of 7 Old 08-29-2006, 05:37 PM
miguelitojeep97
there are a couple of guys running 37s in our group one had currie 9s and the other two have 44s F/R. Im not a very aggressive driver on the rocks but do you think like a Goodyear 37 inch would hold up to F/R D44s? Maybe even throw some Alloy shafts in there? just curious I want to be bigger in the future for as cheap as I can. Was thinking about building 60s on the side but think that would take a long time and real expensive
1997 TJ 4.0 5 spd. rock track 4:1, 3.5 inch Rock Krawler 5 inch stretch long arm, 35 inch MTRs, Warn 9k, D44/30 locked with 4:88s, Vanco BIG BRAKES!!and more...
miguelitojeep97 is offline
post #6 of 7 Old 08-30-2006, 05:01 PM
Swamp Boy
Swamp Boy's Avatar
If you are gonna run 37" MTR's I think you will be fine with 44 F/R Put some good Ujoints in the 44 and the rear will probobly hold up OK as long as you are not giving it hell...
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #7 of 7 Old 08-30-2006, 06:31 PM
((~JEEP~))
Guest
I run 35's on my Sahara with the D30F and D44R, no problems
((~JEEP~)) is offline
Upgrading 33" tires to 35" tires on a 4" Lift edward7035 Tires & Wheels 4 02-19-2012 10:45 PM
35" 16R tires who makes 9-10.5" wide radial mud tires van1 Tires & Wheels 4 01-18-2010 06:06 AM
Are interco/cooper tires "true size" tires? jzmtl Tires & Wheels 2 11-15-2006 05:21 PM
Lift and Tire Pics -- RE 3.5" with 1" BL 1" MML & 32x12.50 Tires newgene Tires & Wheels 14 06-22-2005 11:24 AM
