Clutch problem on a yj - JeepForum.com
post #1 of 3 Old 07-13-2020, 06:26 PM Thread Starter
hampton_30
I have a 94 jeep wrangler yj I replaced the clutch, pressure plate, throw out bearing,pilot bearing,fly wheel, slave cylinder, master cylinder , and clutch fork. Worked great for 24 hrs then nothing but problems now you can put it in gear while it's running first thing in the morning after its sat all night but after a few minutes it switches to not allowing me to put it in gear while it's running sitting at a stop. But if you get ot into first gear before you stop the clutch will hold it in place tell you let up on it. I have replaced all these parts 3 times in the past week and each time it does the same thing I'm really lost and cant figure out what is goin on has anyone ever had this problem
hampton_30 is offline
post #2 of 3 Old 07-13-2020, 11:31 PM
mukluk
mukluk's Avatar
First thing that pops to mind is the clutch disc is sticking on the splines of the transmission input shaft or the end of the input shaft is sticking in the pilot bearing. This will prevent the clutch from fully releasing, regardless of how well the release bearing and pressure plate work.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 3 Old 07-14-2020, 01:32 PM
Goatboy4570
Goatboy4570's Avatar
1983 CJ7
The hydraulic clutch may need to be what is called pressure bled , some hydraulic clutches cant be bled out by just pumping the peddle ???
What does your shop manual say about bleeding the system ?
Goatboy4570 is offline
