Cleaning the Transmission and Transfer Case - JeepForum.com
 2Likes
  • 1 Post By ChrisHager
post #1 of 5 Old 07-31-2019, 06:56 AM Thread Starter
Wojoe
Wojoe's Avatar
Hi all I got my trans and transfer case out. What's a good way to clean all the grease and grime that has accumulated over the years. I do not want to break open any cases. Just want to clean them up and put a coat of paint maybe.
Thanks Joe
Wojoe is offline
post #2 of 5 Old 07-31-2019, 07:27 AM
ChrisHager
Administrator
ChrisHager's Avatar
Oven cleaner.
Wojoe likes this.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #3 of 5 Old 07-31-2019, 03:34 PM Thread Starter
Wojoe
Wojoe's Avatar
Can I hose off the case too. Is water going to get into places I don't want it to?
Wojoe is offline
post #4 of 5 Old 08-01-2019, 07:09 AM
ChrisHager
Administrator
ChrisHager's Avatar
As long as it's sealed up, you should be good. I would slap some tape on any areas you don't want water to enter and avoid direct spray on said areas. There's a chance the oven cleaner will darken the aluminum but if you're going to throw a coat of paint in it, you'll be good.
I used a few cans on my T-18A/D20 then painted them up a bit. I found the gel/foam type to work better compared to the liquid spray that runs right off.
Wojoe likes this.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #5 of 5 Old 08-01-2019, 07:31 AM Thread Starter
Wojoe
Wojoe's Avatar
Thanks for the advice. I will try this out today.
Wojoe is offline
