CJ7 TH400 Transmission Question - JeepForum.com
 1Likes
  • 1 Post By HAZCAT
post #1 of 2 Old 02-28-2019, 11:58 AM Thread Starter
sheadberg
sheadberg's Avatar
1979 CJ7
'79
TH400 Auto 3 speed transmission
Quadratrac Transfer Case
After driving about 15 miles, transmission slipped but then reengaged almost immediately. Another mile down the road did so again and finally seemed to have lost all forward gears but had reverse. Flat bedded home. Next day started and drove short distance, progressed through all 3 gears but only short distance, didn't have time to warm transmission. Any thoughts why I would have lost forward gears only to have them return next day?
sheadberg is offline
post #2 of 2 Old 02-28-2019, 12:39 PM
HAZCAT
HAZCAT's Avatar
Might want to check the transmission fluid before you do a whole lot. I had a similar issue in one of mine years back and the fluid was almost gone. Had a leaking seal that I didn't notice as it was one of several Jeeps I had back then and where it was parked, I didn't see fluid on the ground as the leak was slow but after awhile it drained out enough...that was my issue anyway.
Jbaum likes this.
'84 CJ7, 44, 14 bolt, twin stick 300, 109"whl base, 4 linked
'93 XJ Cherokee
'70 CJ6 Dauntless v6
HAZCAT is offline
cj7 , questions , transmission
Auto to Manual Transmission Swap TheFreedombird TJ Wrangler Technical Forum 43 01-09-2020 11:10 AM
CJ7 Transmission sheadberg Engines & Drivetrain 1 02-11-2019 10:35 AM
Automatic Transmission Question Islander91 WJ Grand Cherokee Forum 5 03-21-2018 07:29 PM
CJ7 - tire/gearing question moriartii Jeep CJ Forum 18 11-27-2017 05:24 PM
1978 CJ7: How to tell if a 32RH transmission is going into direct drive? GITanker Jeep CJ Forum 0 03-03-2017 10:00 AM
