Can"t find reverse after being stored 15 years. 1981 cj5 - JeepForum.com
post #1 of 3 Old 10-17-2020, 10:41 PM Thread Starter
Kaukura
1981 CJ5
Aloha
Pulled it out, ran through it, changed this and that, fixed this and that and took it for a test drive. Runs great!
However, I can't find reverse. 1st, 2nd, 3rd and 4th are flawless.
Can push down on the shifter and it seems normal, but it won't go past the 3rd/4th line and pull down into reverse. It just goes into 4th.
Hoping this is something simple from sitting. Need to free up a stuck something or other.
Thoughts? Thanks!
Kaukura is offline
post #2 of 3 Old 10-18-2020, 09:25 AM
Rldsl
After that may yearsitrare, but possible for a bit of surface rust to be sging it up inside. Wouldn't hurt to pop the cover and see ad once it's open you can tap that reverse gear ( carefully)with a wood dowel and get it moving. Wheels up on jack stands a good idea.
Rldsl is offline
post #3 of 3 Old 10-19-2020, 12:01 PM
Fourtrail
1974 CJ6
1981 would have had an SR-4 behind the 4 cyl and rev is over to the left and up, not to the right and down.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
