Cam considerations for passing - JeepForum.com
 2Likes
  • 1 Post By snowbuggy
  • 1 Post By Kruzin
post #1 of 14 Old 07-31-2020, 04:34 PM Thread Starter
davecove
davecove's Avatar
1995 XJ Cherokee
I am in the middle of a '95 4L rebuild and am considering a different cam.
I will be using this Jeep as a daily driver on an island with winding roads and frequent encounters with slow moving traffic. The nature of the roads limits top cruising speed to about 45mph max. The ability to go from 25 mph to 45 or 50 mph in the available straight(ish) stretches like a spooked rabbit is what I need.
I'm thinking about one with a .40 lift on the intake and a .50 on the exhaust but I am unsure about the advance, duration and separation.
I'd love to hear your thoughts on this and any other mods I can make to the drive train to improve pickup and passing performance.
davecove is offline
post #2 of 14 Old 07-31-2020, 04:45 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
If you're in a 45 max MPH environment and looking for performance, just swap the gears. If it's an automatic, swap in a male transmission.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 14 Old 07-31-2020, 04:48 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Re-gearing the axles would take care of it without having to mess with trying to get it tuned properly for a different cam.
From the factory, the Jeep was geared to run at highway speeds. If you never get to highway speeds, you can gear it for a lot more low end power.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 14 Old 07-31-2020, 05:47 PM
jtec
jtec's Avatar
2014 JK Wrangler
FWIW in my archives.
THe guys are right GEARS - MAYBE MAYBE tire size a thought... Smaller?
https://cdn.xjjeeps.com/pdf/en-us/je...ines-guide.pdf
jtec is offline
post #5 of 14 Old 07-31-2020, 06:20 PM Thread Starter
davecove
davecove's Avatar
1995 XJ Cherokee
It's got stock tires right now but we want a 3" lift and 31" tires so a regear is certainly in our future now.
Thanks for the manual!
Sent from my moto x4 using Tapatalk
davecove is offline
post #6 of 14 Old 07-31-2020, 10:35 PM
80cj
80cj's Avatar
1980 CJ5
Just curious, what island are you on?
80cj is offline
post #7 of 14 Old 08-01-2020, 10:46 AM Thread Starter
davecove
davecove's Avatar
1995 XJ Cherokee
Really stupid question here: Do the front and back ratios need to be the same?
davecove is offline
post #8 of 14 Old 08-01-2020, 11:06 AM
222Doc
222Doc's Avatar
yes
222Doc is online now
post #9 of 14 Old 08-01-2020, 01:17 PM
4Low2G0
4Low2G0's Avatar
If you're planning larger tires and want better acceleration, then for sure gears, and a good tune up.
Whats over that next ridge?
4Low2G0 is offline
post #10 of 14 Old 08-01-2020, 01:32 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Definitely need to be the same ratio, otherwise the axles will be trying to spin at different speeds and something in between (likely the t-case) WILL go SNAP.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #11 of 14 Old 08-02-2020, 07:40 AM
snowbuggy
a male transmission? Now that's funny. I always like female transmissions so I can drink a beverage while I'm driving lol.
davecove likes this.
snowbuggy is offline
post #12 of 14 Old 08-02-2020, 03:21 PM Thread Starter
davecove
davecove's Avatar
1995 XJ Cherokee
So would this do the trick moving my front axle D30 up to 4.10?
https://www.quadratec.com/products/52419_2004.htm
Seems like a good brand (Dana) and a good price.
davecove is offline
post #13 of 14 Old 08-02-2020, 03:49 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
That's only for the front axle and it's only the gears. Personally, if I were tearing the axle apart to re-gear it, I'd also replace the bearings.
You'll also need shim packs and bolts (never re-use old diff bolts) and a few other odds and ends.
What you should be shopping for is what they call "master install" kits, which will come with all those extra items you are going to need.
For what you're talking about, I think 4.10s aren't enough. Especially if you're going to go to bigger tires. With the bigger tires and your need for more low end grunt and no need for top end speed, you might want to go more radical than just 4.10s
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #14 of 14 Old 08-02-2020, 06:11 PM Thread Starter
davecove
davecove's Avatar
1995 XJ Cherokee
Yeah, I know about all of those extra parts... I've been watching A LOT of YouTube videos on rebuilding the D30. One thing tho... my unit has a pair of giant red o-rings just outboard of the diff bearings. I haven't seen those in many videos and am wondering what they are for.
I was wondering if 4.10 would be enough... Not opposed to 4.56
davecove is offline
