Buying a Used Transfer Case - JeepForum.com
post #1 of 4 Old 04-23-2017, 09:27 PM Thread Starter
Johnwazup
I'm lookin to buy an old NP 242 transfer case and *possibly* a used manual 5 speed nv3550. This will be used to convert my jeep into a 4x4.
When looking for a used transfercase/tranny, what should I be looking for or test to see if that part is not defective? Last thing I need is losing a couple hundred bucks on buying a defective part. What can I do minus slapping the part in a working jeep and running it around the block?
Thanks
Johnwazup
Johnwazup is offline
post #2 of 4 Old 04-24-2017, 06:39 AM Thread Starter
Johnwazup
Bump
post #3 of 4 Old 04-24-2017, 09:10 AM
biffgnar
biffgnar's Avatar
Either running it or opening it up seem like only ways to be certain.
biffgnar is offline
post #4 of 4 Old 04-26-2017, 10:51 AM
u2slow
2005 KJ Liberty
I wouldn't worry too much. The 90's XJ ones are so cheap you can take your chances. Buy a 2nd one if you get a dud. Make sure the spline matches your 5spd... should be 23.
If you want one of the heavier-duty (and longer) WJ or Durango units, they're a bit less common. I'd probably get one of those from a wrecker with a warranty.
2005 KJ V6/6spd/3.73posi & np242 swap, 3" lift... and some Dodges w/cummins
u2slow is offline
buying , tips , transfer case
