AX15 questions for the gurus - JeepForum.com
post #1 of 3 Old 07-09-2010, 06:23 AM Thread Starter
lespaul_custom
first off thanks for any answers and your help alright so my ax15 died on me. i bought one out of a 1999 xj with low miles. i have everything for the swap. i know the transfer case is clocked different on the xj so my question is to avoid cutting and welding on the skid plate and a possible tc drop kit. can i just swap out the tail housing from my old one?? will it fit?? once again thanks for your time i appreciate it
originally posted by urb4ntroll
The weird thing is that I thought I hear a minor bang, almost like a fart sound coming out of my Jeep, but I'm not sure what it was. It has never happened before the glue incident.
white jeep club #1993 looking to buy complete rear seat belts
lespaul_custom is offline
post #2 of 3 Old 07-09-2010, 05:21 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Just redrill it. It's soft aluminum & will easily drill out with a hand drill.
When using a non YJ AX tranny in a YJ, the NP231 transfer case will hit the skid plate because the T-case is "clocked" 10 degrees lower on the driver side, but you can redrill the location of the mounting holes at the rear of the transmission.
The transfer case clocking is determined by the mounting holes on the output of the transmission. Simply redrill the holes to raise the transfer case to the YJ height. In this pic, the holes on the right on each tab are the newly drilled holes that the YJ configuration requires to clear the skid plate.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 3 Old 07-10-2010, 01:26 AM Thread Starter
lespaul_custom
i may go that route!!! alot easier then taking things apart i guess!! thanks max
ax-15
Oil gurus, Magnet on the oil pan? Hussler Engines & Drivetrain 10 05-17-2010 11:30 AM
CB gurus please help chondamx Audio, CB & Ham Radios, GPS, & Electrical 19 03-02-2007 04:58 PM
Electrical gurus and foglight gurus... dali555 Audio, CB & Ham Radios, GPS, & Electrical 8 01-21-2007 06:45 PM
One for the CB gurus sentinal02 Audio, CB & Ham Radios, GPS, & Electrical 30 02-02-2006 12:02 PM
CB Question for the Gurus frhalevt Audio, CB & Ham Radios, GPS, & Electrical 4 02-26-2004 02:04 PM
