Anybody cammed the 4.0? Change the ignition/fuel maps? Tune on the dyno? - JeepForum.com
 1Likes
  • 1 Post By heepzeegay
post #1 of 6 Old 12-26-2017, 01:22 PM Thread Starter
heepzeegay
I have had jeeps for a while but this is the first one I have had that is altered from stock a little bit. I got .060" oversized pistons and a comp "extreme 4x4" cam in my build. Had it going for a while but I get hesitation/pings/misfires down low. Anybody have any experience with tuning/chips for changing fuel maps. I am assuming somebody has built a stroker 4.7 here that needed a tune. I was wondering if anybody has had experience using hypertech, jet, etc...to change their tune.
heepzeegay is offline
post #2 of 6 Old 12-26-2017, 02:28 PM
biffgnar
biffgnar's Avatar
I believe for most 90s and even early 2000s, DC programming has not been cracked very well and most people use piggybacks.
biffgnar is offline
post #3 of 6 Old 12-26-2017, 06:22 PM
scotch737
scotch737's Avatar
What year? What intake you running? Without head work, might be wasting time. Possibly injectors could help, if they can be tuned that is. But with pings misfires at low rpm. Might be a timing issue/possible fuel. What's your timing set at?
Originally Posted by PolkaPower View Post
At least they have perfected boob jobs. You can't even tell anymore. That's one good thing.
My TJ-6 LS swap Build:
scotch737 is offline
post #4 of 6 Old 12-28-2017, 11:44 AM Thread Starter
heepzeegay
As far as I know, running stock timing. I set the dizzy like I would have on my other 4.0's. The timing chain was set by the engine builder/machinist. Stock 96 ZJ intake manifold. The cam is not supposed to be super aggressive so I don't neeed head work like a port and polish but I did have the valve train done as well as the lifters.
post #5 of 6 Old 12-29-2017, 04:53 PM
scotch737
scotch737's Avatar
Try giving it two degrees advanced for up to 12. Go in 2 degree increments.. See if it helps any.
post #6 of 6 Old 12-31-2017, 02:48 PM Thread Starter
heepzeegay
I wish it was that easy. The timing is really only adjustable ~28 degree increments due to the 13 teeth on the distributor gear. The thing locks in only one way. Computer is responsible for timing ignition according to cam/crank sensors. I'm waiting for a day above 5 degrees to get back out there.
scotch737 likes this.
