99 am misfire rough idle - JeepForum.com
post #1 of 12 Old 08-02-2021, 08:36 PM Thread Starter
Thurmand92
1936 CJ2A
Ok, I have a 99 wj with the 4.0 trying to figure out my rough idle issue. I have a code for the trans govonor pressure sensor but no other codes. Had an issue with stumbling and cutting off but resolved that by replacing cam and crank sensors. Have also replaced o2 sensor, TPS, and sparkplugs. Can the trans pressure sensor cause a misfire like symptom?
Sent from my LM-G710VM using Tapatalk
Thurmand92 is offline
post #2 of 12 Old 08-03-2021, 07:51 AM
jtec
jtec's Avatar
2014 JK Wrangler
I am guessing your CEL is on, have system scanned (free at many part stores) pst ALL codes the scanner retrives.
Have you cleaned the IAC?
Have you checked fuel pressure, with a gauge?
Looked at spark plugs? Black, wet, dry, tan ? What plug # champion xyz?
Is engine reaching temp @220degF ?
jtec is offline
post #3 of 12 Old 08-03-2021, 07:55 AM
jtec
jtec's Avatar
2014 JK Wrangler
[QUOTE=jtec;41326767]I am guessing your CEL is on, have system scanned (free at many part stores) pst ALL codes the scanner retrives.
Looked at spark plugs? Black,wet,dry,tan ?
What plug IIRC champion - RC12ECC?
jtec is offline
post #4 of 12 Old 08-04-2021, 04:51 AM Thread Starter
Thurmand92
1936 CJ2A
[quote=jtec;41326769]
P1762
P1763
Have cleaned IAC
Replaced TPS
Plugs are NGK 3459
Haven't checked current condition replaced beginning of july
Unknown fuel pressure
post #5 of 12 Old 08-04-2021, 07:06 AM
jtec
jtec's Avatar
2014 JK Wrangler
do you have a scanner - view live data?
jtec is offline
post #6 of 12 Old 08-04-2021, 12:52 PM Thread Starter
Thurmand92
1936 CJ2A
Do not have a live scanner
post #7 of 12 Old 08-05-2021, 01:13 PM Thread Starter
Thurmand92
1936 CJ2A
Got some live data at idle discovered a misfire on cylinder2
post #8 of 12 Old 08-05-2021, 02:15 PM
jtec
jtec's Avatar
2014 JK Wrangler
I can't read that -
Can you post
ECT engine temp
MAP reading vacuum
TPS throttle reading
fuel trims long and short don't forget the + or -
o2 sensoe swings - precat sensors ie .02 to .07, or stuck at .0x
Also if the snappy displayed any codes.
jtec is offline
post #9 of 12 Old 08-05-2021, 06:39 PM Thread Starter
Thurmand92
1936 CJ2A
ECT engine temp. 190
MAP reading vacuum-- 18.6
TPS throttle reading-- 0.78v
Throttle 0%
short 0.0
Long-7.3 when doing purge vapors test
But short 0.0
Long 0.0 when in live view
o2 sensoe swings - not sure
Only codes were the previous trans codes I mentioned before
P1762
P1763
post #10 of 12 Old 08-06-2021, 03:00 PM Thread Starter
Thurmand92
1936 CJ2A
Spark plugs all look about the same
post #11 of 12 Old 08-06-2021, 03:11 PM Thread Starter
Thurmand92
1936 CJ2A
Also got a p0302 and a p0132 code today
post #12 of 12 Old 08-19-2021, 09:34 AM Thread Starter
Thurmand92
1936 CJ2A
Fixed problem Sith new coil rail and pigtail adapter to adapt the 99 wiring to a 2000-04 coil rail
