95 YJ engine replacement - JeepForum.com
post #1 of 4 Old 08-13-2020, 11:26 AM Thread Starter
lew95yj
Any good suggestions on replacing the stock 4 cyl to either a Jeep 6 cyl or a small block v-8? Need more towing power on road for a 18' aluminum boat and 10' utility trailer. Thanks
lew95yj is offline
post #2 of 4 Old 08-13-2020, 11:43 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
There are plenty of options, what is your budget, and who is going to do the work ? Will it need to pass a smog test ?
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 4 Old 08-13-2020, 12:05 PM Thread Starter
lew95yj
Do not want to spend more than Jeep is worth. No on the smog test . If the replacement is non-computer driven then I will change out and let the grandson learn as well
lew95yj is offline
post #4 of 4 Old 08-13-2020, 03:55 PM
4Low2G0
4Low2G0's Avatar
An engine swap is never really easy or cheap, finding a rusty or wrecked 95 4.0 YJ would be simplest.
Swapping out the 4 cyl. you'll have to swap the trans too if it's a stick,not sure about an auto.
I suppose you could get a 258 in there with no computer but why? and you'd still need a trans...
Anything else will require welding etc.
Not sure I'd tow much with my YJ... just sayin...
Whats over that next ridge?
4Low2G0 is offline
