95 Grand Cherokee auto, transmission slow to shift to first at stop like after warm - JeepForum.com
post #1 of 4 Old 02-15-2018, 10:52 AM Thread Starter
digdug18
New to me Jeep Grand Cherokee, automatic. When cold it shifts completely normal. But once warm, the transmission is slow to engage first when starting out, then it slams into gear and goes.
Can someone point me in a direction in which to start diagnosing this? Or is this a common problem and you know what the cause is?
Andrew
digdug18 is offline
post #2 of 4 Old 02-15-2018, 12:29 PM
jtec
jtec's Avatar
2014 JK Wrangler
does it shift all gears, downshifts ?
before a trans diagnostic ck with dropping pan band adjustments and gauges I would -
check fluid - quantity, color and any particles in fluid.
TV cable adjustment,
Check for codes- don;t know till you look.
jtec is offline
post #3 of 4 Old 02-16-2018, 10:24 AM
wingless
wingless's Avatar
1994 ZJ
The OP should update his profile to ID the engine, along w/ the previously identified year and model.
wingless is offline
post #4 of 4 Old 02-16-2018, 02:11 PM Thread Starter
digdug18
When it's cold or luke warm, it shifts normal. Up-shifts and down-shifts and converter lock-up are completely fine.
I haven't played with it at all, it's been raining, nothing sucks like laying underneath having rain drip on you.
It's the I-6, automatic transmission. Thanks for the suggestion, but I wasn't planning on adding anything to my profile.
digdug18 is offline
